Hey Guys,
My current benching system consists of -
FX60 @ 3.45Ghz 1.55V
Saphire X1900 XTX 680 \ 900 limited by PSU
2 x BH-5 @ 26? 3.4V
PC&P 850SSI
Mach 2 GT (Stock)
My problem is I get system resets running 3D at higher overclocks than the one above!!! I believe its the psu's ovp kicking it on the pci-e channel of the psu!!!
ATItool reports the X1900XTX as using 26.5a when at 700 \ 900, can the amperage info supplied by ATItool be trusted?
Would it be safe to connect both PCI-E connectors together to create 1 channel with 32a max power instead of 16a?
