I was wondering if there are any refrigerants better then R507 to run on a single stage. Lower boiling point is generally a better refrigerant for our purposes, but normaly the lower the boiling point is the harder it is to condense the refrigerant which I means you need a better condenser and more powerfull compressor. So is there a better refrigerant then R507 to use in a single stage setup with 1/3-1/2hp unit and a small computer case sized condenser?
