    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 24 of 24
Thread: liquid helium cooling?
    Aug 2004
    Is it even feasible, or is there not much benefit going below the temps of LN2?
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Welcome to XtremeSystems!
    It is much colder but harder to work with and obtain in the liquid form.
    I have a Helium scroll compressor that was put on the back burner.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Xtreme Hardware Killer
    Jan 2004
    Behind you
    I heard your cpu can't operate at a temp that low, plus fugger is right, it's really hard to get. I tryed to get some and they asked if I had a license.
    Level 80 UD Death Knight on Murmur (Beta)
    Feb 2004
    Tucson, Az, USA
    Generally silicon will not work as a semiconductor at those temperatures (it becomes an insulator without a minimum of thermal energy to promote valance electrons to the conduction band). However AMD and Intel do some weird stuff to the silicon they use in order to boost performance and decrease energy use, so I really don't know what would happen.
    I wouldn't be surprised if the chip simply did not boot though until you let it warm up a little.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    well afaik the old P4's and P3's and athlons dont care about very low temps, but the newer cpus wont boot or will crash below -140C.
    Aug 2004
    Wouldn't that mean that you couldn't use ln2?
    Jan 2004
    Behind you
    In theory yes, but it's not truely -192C it hovers somewhere around -120-90C to be about right.
    Apr 2004
    Norway
    I have been wondering abaut the same thing, since I was reading abaut it in my chemical book
    Jul 2004
    Helsinki, Finland
    Sorry but you are wrong
    LN2 really evaporates at ~-196, depending on the air pressure. It really hovers around -194 .. -198 celcius. If you shut down your computer, and it's well insulated, the bottom of the tube should be around -196 celcius after you pour it full of LN2. If your computer is on, and processor is making heat, naturally it won't go as low as -196.
    If you claim that liquid nitrogen evaporates as -90 ... -120 C, or that it's the lowest baseplate temp achievable with LN2, you have a crappy thermometer
    My baseplate temps measured with that thermometer, it's LN2 in the cup
    Asus P4C800-E Dlx, P4 2.8A @ 5.575GHz
    Asus P5P800, P4 550 @ 5.1Ghz
    SuperPi 8M : 4 min 14s
    X.I.P.
    Oct 2002
    Australia
    One of the many problems with liquid He is the latent heat of vapourisation is only 2.56 kJ/litre. At a load of 200W you'll consume approx 4.7litres/minute. Thats one expensive overclock
    here a link with some comparitive data
    http://www.lancs.ac.uk/postgrad/grif...yoliquids.html
    X800Pro class 3DMark01 : 36670
    X800Pro class 3DMark03 : 16092
    Ti4200 class 3Dmark01 No 1 : 22213
    Super Pi 1M : S754 28 sec, FX53 25 sec
    HEXUS Pifast : S754/Prom 40.55sec, FX53 36.92sec
    Author of A64 Tweaker
    Co-author of NF2 Tweaker
    Mar 2004
    So-Cal
    Quote Originally Posted by Hilppa
    I think he means core temps....
    Sep 2004
    Andover, Massachusetts, USA
    i had always thought CPUs shut down at -178C and some VPUs and -128C or something, please correct me, experiences members...
    Hail to extreme cooling!
    HVAC/R Engineer
    Nov 2003
    In Las Vegas Ln2 boils at -350F or -212C
    Apr 2004
    Herning, Denmark
    need a bit of work for that
    Oct 2004
    Crazypc.ro
    Quote Originally Posted by chilly1
    y?
    atmospheric presure???
    Oct 2004
    It seems to me that they could make a cpu out of a superconductor so that the xtreme temps of liquid He2 could be put to good use.
    Apr 2004
    Herning, Denmark
    Quote Originally Posted by quintus
    y?
    as i wrote, need a bit of work for that
    he is pumping it wih a vacuumpump, so it boils at lower temp.
    look at the topic he made about it..
  18. #18
    Help, Help!!
    Have been doing lots of LN2 project the past 4weeks with many different boards and the QX9650. I have a question if anyone can answer it for me.
    with my tube correctly mounted on the processor filled with LN2 if I let it sit there for awhile then try to boot the board starts then shuts down. we have insulated, rigged little electric coils around all the caps near the socket and have followed pretty much all the standards for LN2
    maximux extreme
    QX9650
    corsair 1800 DDR3
    1200watt thermaltake
    2 3870 x2's
  19. #19
    Xtreme Cruncher
    Nov 2006
    'burb of Cleveland, Ohio
    Three and a half years since the last post in this thread... Impressive.
    You probably have it too cold. Take the LN2 out of the tube, let the processor warm up, then put some back in the tube. It wont boot colder than -140 or so.
  20. #20
    Aug 2004
    Dude, come on. I'm not going to ask how far back you had to look to find this thread, but what made you think that your post was even remotely relevant?
  21. #21
    -100c Club
    Jun 2005
    Slovenia, Europe
    Liquid helium isn't usefull since you have to consider the superconductivity effect. Most metal & metal alloys becomes superconductive at around -205 ~ -210°C, some ceramic materials already at -170°C. Not to mention helium has a very very poor thermal conductivity, far worse than that of LN2 (and even nitrogen's therm. conducitivy sucks compared to water).
    Therefore, no good use for helium in computer overclocking.
  22. #22
    Aug 2007
    Cumming, IA
    Quote Originally Posted by tiborrr View Post
    True.
    Excellent zombie thread by the way.
    Polizei is probably right. The chip will not boot at that low of a temp. Do as he said and see if it works.
    There are lots of ways to control temps, it just takes practice. Once you find roughly the low limit of what your CPU will boot at, you can use your thermometer and a bit of creativity to keep from going below it.
    XBOX Gamertag:Fujimitsu - I'm lonely, be my friend!
  23. #23
    If you don't mind me asking, what are some of these ways. Sorry to sound like a newby but I am with the LN2. I tried a little water to make a small block of ice on the bottom of the tube. This didn't do much good though.
    thanks....
  24. #24
    Aug 2007
    Cumming, IA
    Quote Originally Posted by johnny m View Post
    thanks....
    The ice thing works, as would controlling the amount of LN2 you pour in.
    Might wait for some more experienced ln2 overclockers to chime in, maybe they have some secrets for you.
