https://www.techpowerup.com/230186/a...lus-cpu-cooler
Arctic unveils the Freezer i32 Plus CPU cooler. The enhanced ARCTIC Freezer i32 Plus comes up with an additional Fan to cool down much-engaged CPU's. Both fans are mounted on opposite sides of the radiator and thus provide a great airflow. The first fan pushes air through the heatsink, the second fan pulls the air out of the heatsink.If you really need a silent cooler, one that only turns on when you really need it, then maybe the ARCTIC Freezer i32 is the cooler for you. Arctic started with an ideal use case and created a product that matches it perfectly. Available now, the Freezer i32 Plus is priced at 49.99?.
