Here are some of the first pictures of XFX Radeon RX 470 Double Dissipation, the company's premium RX 470 offering. The card features a dual-slot custom-design cooling solution, featuring an aluminium fin-stack heatsink to which heat drawn from the GPU is fed by copper heat pipes; and dissipated by a pair of 90 mm spinners. Also featured is a back-plate running the length of the PCB. The card draws power from a single 6-pin PCIe power connector. Display outputs include three DisplayPort 1.4, and one each of HDMI 2.0b and dual-link DVI. The card is expected to launch on the 4th of August, 2016.
