I have a thread running in the Intel section about my new build; however, I have two main issues I'm needing help on (GPU & Cooling) which appear to be outside the bounds of that Forum. Most of the information can be had here (Link), but I'll put in the relevant here.
I'm building a new Dual-Socket Xeon E5-2600 V2 Series based Workstation for 2 primary uses, CGI Rendering (Maya / Maxwell / Zbrush / RealFlow) and Gaming (RTS ONLY!! No FPS/Crysis, etc.).
This thread is focused on the Cooling issue. I'm extremely undecided between Air cooling & Water cooling.
I have never done Water cooling before; so there is a n00b risk involved (leakage; proper installation, etc.), but at the same time - as a long-time custom builder, I'm extremely interested & anxious to try my first Water cooling -- The only possible hardware mod I haven't put my hands on yet. Also, I live California, and although I have an A/C in the room where the machine will sit, I don't necessarily run the A/C 24/7. The Workstation will generally *NOT* be running 24/7 either -- EXCEPT when Rendering. It could be running for 5 days or 10 days non-stop when rendering!! All CPU Cores running at 100% continuously during rendering will generate heat - regardless of Xeon or not. It's a fact.
On the other hand, Xeon's don't overclock & Watercooling is traditionally synchronous with Overclocking. More importantly, even though I will be starting with a single CPU, I will be adding a 2nd CPU within 3 ~ 6 months. Watercooling a single CPU is obviously far easier & probably a good starter then Watercooling 2 CPU's. Air cooling 2 CPU's is a breeze (no pun intended!).
Cost is not an issue here; which favors Watercooling since it's more expensive then Air.
There's obviously arguments that favor/disfavor both; so to sum it up:
Air Cooling
Pros:
- Simple & Cheaper; No leakage risks; No technical knowledge required.
- Easy & Simple support for 2 CPU's.
- Practically Maintenance-Free.
- Xeon's can't Overclock; No OC'ing involved.
Cons:
- Not sure if it's enough for continuous multiple-day spanning rendering jobs w/ CPU Cores at Constant 100%
- California Heat!! Not running room A/C 24/7 even when Workstation running 24/7 for rendering.
- Definitely not as cool at Water cooling
- No fun installing & running Air! (I know - pathetic excuse - sorry!)
Water Cooling
Pros:
- Learning something new; way cooler then Air cooling
- Will keep CPU's cool during rendering job; even with room A/C off.
- Cost is not an issue; will complement an otherwise powerful rendering & gaming beast.
Cons:
- Leakage risks; learning curve; possible mishaps & disasters!!
- Xeon's can't Overclock; Watercooling for stock speeds!
I want to make a good, informative choice, and I'm hoping members here can push me on one side or another.
Thanks!
FYI: Current "early" possible(s) ...
CPU: Xeon E5-2660 V2 (September 2013) -- $1,590
Motherboard: ASUS .OR. Supermicro (Undecided/Waiting to see new models for Xeon V2) -- (Approx. $400)
GPU: 2 * 8000 Series Crossfire (September 2013) -- (Approx $850)
Sound Card: Creative Sound Blaster Z 70SB150000000 5.1 PCI Express x1 -- $90
Memory: 2 * Kingston 16GB (4 x 4GB) 1600 ECC Unbuffered -- $356
PSU: Corsair AX1200 GOLD .OR. Thermaltake Grand TPG-1200M GOLD -- (Approx $250)
SSD: 2 * SAMSUNG 830 Series MZ-7PC128B/WW 2.5" 128GB SATA III MLC (RAID1) -- $199
HDD: Seagate ST2000DM001 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s -- $99
Case: Thermaltake Level 10 GT (VN10001W2N) -- $239
Cooling: Air .OR. Corsair H100i Liquid Cooling -- $99
Monitor: ASUS VE278H Black 27" 2ms (GTG) HDMI Widescreen LED -- $249
Keyboard: Microsoft SIDEWINDER X4 -- $49
Mouse: Razor Orochi Bluetooth (Already Own) -- $0
