Hello
One more unit, this time it is not standart . It is "cold plate" chiller in orginal vapochill LS case.
Don't ask me for what is that - I have order for it so I make it . Planned load is approx 0W. I'll be used to cool other metal plates (scientific experiments).
Goal was -30C somewhere on plate- I get approx -43C with final tune . It has eliwell controller so temperature can be risen.
SPECS:
Compressor: Aspera NEK2134GK
Evap: 4mm thick copper plate 20x20cm cooled by 3/8' roll pipe - evap mounted between copper and alu 3mm thick (sandwich)
XV: captube 0.8 mm
Condensor: stock vapochill LS + 120mm/38 12V Panaflo fan + 120mm/38 12V Nidec fan
Refrigerant : R507
Case : stock Vapochill LS case
Others: Eliwell IC915 controller,Panaflo 120x38mm 12V fan on back of case
"tool" for making roll evap
Not perfect but it is best I can make .
Milled.
And the sandwich is ready.
Now we take 100% stock vapochill LS.
After less than hour ...
Owner will mount NTC probe to controller (that is why it reads "E1" - no probe plugged).
With Kindest Regards
Peter
