Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Swiftech H220 Complete Review Part # 1 of 2
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Post Swiftech H220 Complete Review Part # 1 of 2
    Swiftech H220 Review
    Introduction:
    Swiftech is a company that has been in the hardware cooling sector for around 20 years fullfilling the needs of an ever growing computer enthusiast and novices alike croud with the desire to go for better than stock cooling on their hardware , with such a vast experience under its belt they accomplish a task no other company has done before , yes that's right the have bridge the gap between the all in one liquid cooling closed loop kits and the do it yourselves customizable kits , a huge milestone accomplished by Swiftech that will change forever the way you look at the all in one closed loops kits available on the market.
    This is where the Swiftech H220 comes in , an all in one liquid cooling closed loop that is completely upgradable and fully customizable to your needs. An easy to install , completely pre-assemble , pre-fill for you all in one closed loop liquid cooling kit , very easy to install and to work with. For novices and for enthusiast the H220 offers the best performance available as of now in the market beating each and everyone of all the competitions all in one closed loop liquid cooling kits available , the competiton for this H220 are mostly made by Asetek or Coolit in the form of preassemble all in one closed loop liquid cooling kits. The big advantage of the New Swiftech H220 it's all in the quality of the components used to build up this kit , *Powerful high flow pump made in house by Swiftech with their own secret sauce wich is 5 times more powerful than those used on the competition made by asetek or coolit , *Big heavy high performance 240mm cooper radiator , *The legendary Apogee drive cpu cooler water block , *Powerful and silent 2x Helix 120x120x25mm fans with great static pressure and pwm controllable rpm speeds , *3/8 ID very flexible tubing size. But there is more , here is where the H220 obliterate all the competition , the H220 its fully customizable and upgradable , yes you can open this H220 closed water loop all in one liquid cooling kit by simply unscrewing one little screw on any of the 2 conections in the water pump , add some 3/8 ID tubing and you can attached your video card watercooling blocks , chipset watercoling blocks , add more radiators , endless configurations really , you can get very creative with it. All this while been completely silent. You get all this for only $139.95US Dollars and comes with a 3 year full warranty for your peace of mind , the H220 has a MTBF (mean time between failure) of 60,000 hours due to his high reliability and high quality components
    Technical Specifications:
    http://www.swiftech.com/h220.aspx
    Specifications
    1 Radiator
    Material Brass tubes, louvered copper fins
    Body dimensions 269mm x 128mm x 29mm
    Fill-port thread class G 1/4
    Reservoir capacity 90 cc
    Barb fittings Integrated swivel 90? elbows, 3/8" (10mm) OD
    Installation hardware •Standard: (8) coarse thread fans screws
    •Alternate: (8) 6-32 x 1 3/16 (30mm) philips screws
    ROHS Compliant
    2 Pre-installed Fan
    Dimensions 120mm x 120mm x 25mm
    Speed control PWM
    Speed range 800+/- 25% ~ 1800+/- 10% RPM
    Airflow range 24 ~ 55 CFM
    Static pressure range 0.53 ~ 2.29 mmH20
    Noise level range <16 ~ <33 dB/A
    Nominal Voltage 12 v
    Nominal current 0.2 A
    Bearing Type Z-axis
    Connector Mini 4-pin
    MTBF 60,000 hours
    ROHS Compliant
    1 Waterblock with integrated pump
    Cold plate material C110 copper
    Cooling engine 0.25mm x 0.25mm micro-pin array
    Installation hardware •For Intel LGA 775, 1155/56, 1366
    ◦(1) Adjustable back-plate
    ◦(4) Spring loaded screws & washers
    •For Intel LGA 2011
    •For AMD AM2, AM3, FM1,FM2, 939
    ◦(2) Pre-assembled brackts & spring loaded screws
    ◦Bracket installation screws
    Speed control PWM
    Speed range 1200 ~ 3000 RPM
    Nominal voltage 12 v
    Nominal power 6 W
    Bearing type Ceramic shaft, PTFE bearing
    MTBF 60,000 hours
    ROHS Compliant
    2 Tubing
    Material PVC
    Color Black
    Dimensions 5/8" x 3/8" (16/10mm)
    Length 15 3/4" (400mm)
    4 Clamps
    Material Black anodized aluminum
    1 PWM splitter
    PWM Ports 8
    RPM signal port Channel 1
    Power connector Molex 4-pin
    PWM/RPM connector Mini 4-pin
    Installation hardware Peel-off sticker, mounting screws & nuts
    ROHS Compliant
    1 Tim-Mate 2, 1g serynge thermal compound
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Unboxing and accessories included
    The Swiftech H220 comes in a beautiful crafted hard cardboard box with all the technical information all around the box and pictures of the H220 kit. Box feel sturdy , inside the box there is another cardboard box protecting the hardware as well as bubble wrap , protective foam and the screws in plastic bags. Overall very well packed to make sure you receive an undamage and flawless product.
    Accessories included on the kit:
    one water pump
    one 240mm cooper radiator
    one apogee drive cpu water cooler block
    two Helix fans 120x120x25
    two 17 inches long 3/8 flexible black tubing
    mounting hardware for all Intel cpus
    mounting hardware for all amd cpus
    one syringe of high quality team mate thermal paste
    one pwm splitter with capacity to connect up to 7 fans
    four mounting screws pack
    one installation guide
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Testing Methodology
    Hardware used and settings:
    Motherboard: Asus P8Z77-V Pro ( Asus Motherboard selected due to been very stable under high loads/stress and stable under high overclocks )
    CPU: Intel Core i7 3770K
    Ram: 4x4GB G.Skill DDR3 2133 Ripjaws X
    Graphics cards: MSI HD7970 Lightning / Asus HD6670
    OS Drive: Samsung 840 Pro 256GB SSD
    Power Supply: Cooler Master M2 Silent Pro 1500w.
    Contenders:
    Swiftech H220
    Thermaltake Water 2.0 extreme
    Open Bench Testing under temperature control environment at ~20c ambient temperature measure for consistency via UEI DT 304 DMM with a K-Type Probe attached 6 inches away from the fans intake , give or take 3c. Gelid extreme TIM was used on all the mountings of the waterblocks for consistency purposes , I used the method of one small rice size dot of TIM in the middle of the cpu on every mount the same way. A Thermaltake water 2.0 extreme was used to compare the performance of one of the top all in one liquid cooling closed loop kit on the market against the Swiftech H220.
    Default settings used meaning the cpu and ram were run at the motherboard bios default setting speeds on both Kits Swiftech H220 and Thermaltake water 2.0 extreme at the time of testing. fans used on the aio kits were the ones that comes with every kit.
    Overclocked settings used on the cpu were as follow , cpu 3770k at 100x46 multi 4.6Ghz 1.25v in bios LLC high , ram at DDR3-2133 9-11-10-28 1T 1.65v everything else on default bios voltages , all C-States Disabled. Prime 95 small FFTs were run for 15 minutes to load the cpu 100% , maximum average temperature was selected as reference on each run after 15 minutes prime 95 monitoring via core temp program. Two modes were tested on each aio kit on this review , silent fan mode and maximum fan mode at default cpu speeds and overclocked cpu at 4.6Ghz , Also tested was the highest stable cpu overclock attained by each aio kit.
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Performance Data
    Core i7 3770K at Default Bios Settings - Temps in C degrees Fan in Silent Mode at Iddle
    Swiftech H220 26c
    Thermaltake Water 2.0 extreme 29c
    Core i7 3770K at Default Bios Settings - Temps in C degrees Fan in Silent Mode 100% load
    Swiftech H220 47c http://www.youtube.com/watch?v=cZJ_M...ature=youtu.be
    Thermaltake Water 2.0 extreme 51c
    Core i7 3770K at Default Bios Settings - Temps in C degrees Fan in Maximum Mode 100% load
    Swiftech H220 44c
    Thermaltake Water 2.0 extreme 48c
    Core i7 3770K overclock 4.6Ghz 1.25v- Temps in C degrees Fan in Silent Mode iddle
    Swiftech H220 38c
    Thermaltake Water 2.0 extreme 39c
    Core i7 3770K overclock 4.6Ghz 1.25v- Temps in C degrees Fan in Silent Mode 100% load
    Swiftech H220 + added in the same loop an MSI HD7970 using MCW-82 H2O Block 80c
    Thermaltake Water 2.0 extreme cpu only 83c
    Core i7 3770K overclock 4.6Ghz 1.25v- Temps in C degrees Fan in Maximum Mode 100% load
    Swiftech H220 + added in the same loop an MSI HD7970 using MCW-82 H2O Block 78c
    Thermaltake Water 2.0 extreme 80c
    Maximum CPU Frequency Overclock Stable
    Swiftech H220 5106Mhz
    Thermaltake Water 2.0 extreme 5049Mhz
    Conclusion and Reviewer Opinion
    There you have it , there is a new Sheriff in Town and is called Swiftech H220 , The Thermaltake Water 2.0 extreme gets close but cannot overtake nor take the lead against the H220 , also while running all this tests for the last 3 days I come to the conclusion that the Swiftech H220 is in a league of its own , due to the quality of built and high end components , completely silent even on Maximum Fan / Pump Mode , and the upgradability wich is truly a major game changing , the same cannot be said about the Thermaltake Water 2.0 extreme , even in silent mode is noisy and onced you set maximum Fan mode ( extreme setting in TT software ) the fan noise becomes unbearable with a deep huuummm loud sound. I give the Swiftech H220 10 out of 10 because the innovation and revolutionary way it is built to be upgradable and fully customizable all in one closed loop water cooling kit , the complete silent even while running at full speed , easy of use and maintnance free , truly plug and play. This review serves more of a guide of what you can expect of the Swiftech H220 view from an enthusiast like me point of view. Overclocker approved !
    Thank you Swiftech for providing me with this sample of the H220 to make this review possible , thank you Gabe ( Mr.Swiftech ) and Elric (Doc Overclock) Phares.
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Swiftech H220 Review Part 2 , H220 Upgraded and Customized
    Swiftech H220 all in one liquid cooling kit , fully upgradable and customizable.
    What if there was an all in one liquid cooling kit closed loop fully upgradable that could be customized to your needs ? *The wait is over , Swiftech H220 all in one liquid cooling closed loop kit is here and this kit can do that and much more. This is what i have been working on for the last few days , installed on a i7-3770K in a loop with an MSI HD 7970 Lightning added one Swiftech MCW-82 7900 Series VGA water block to the Swiftech H220 all in one closed liquid cooling kit loop , overclocked both CPU and Video Card with added voltages , what do you guys think the outcome will be ?
    Now you can add more water blocks and radiators or anything you can think of , due to the powerful water pump that is variable from 1200rpm all the way to 3000rpm 12 volts 6 watts and controllable via pwm adjustable , with high flow more components can be added , the heavy and well made big cooper 240mm Radiator can handle anything you trow at it , all of this while been completely silence. The game changer , the first all in one cooling kit that can be upgradable and fully customized , it will change the way you think about an all in one liquid cooling kit out in the market as of now. This review comes from an enthusiast point of view and I will not bored you with fancy wording and complicated colorful charts , instead I will let the numbers on the video speak for themselves , I will go down and dirty straight to test the max performance of this all in one Swiftech H220 liquid cooling kit from my entusiast point of view and after extensive testing with added water blocks. Enjoy it what I have been working on !
    Swiftech H220 all in one liquid cooling kit installed on i7 3770k overclocked to 4.6Ghz 1.25v runiing 100% load prime 95 small FFTs 100% stable , in the same loop I added my own MSI HD Lightning 7970 overclocked to 1200/1600Mhz 1.18v using a Swiftech MCW-82 7900 water block with some added 3/8 black tubing, running GPU-Z vga stress test gpu 100% load , both pieces of hardware were running 100% load for 1 hour cooled by one H220, amazing low temperatures for such hot running hardware on one single loop H220 , it can handle that and much more ...
    ( *The sounds you hear on the video are coming from my big window air conditioner and not from the Swiftech H220 or the system running* the Swiftech H220 is completely silent )
    Please check out the video and take a look at the temperatures , those settings were running for one hour non stop and then I took the video , controlled ambient temperature around 20c give or take 1 ~3 degrees:
    http://www.youtube.com/watch?v=BJvdsMwRypI
    Thank you Swiftech for the support !
    Xtreme XIP
    Jun 2007
    Puerto Rico
    reserved 5
    Administrator
    Nov 2007
    Stockton, CA
    Very nice Chispy !
    4.6ghz is what I run my 3770K at and this seems to handle it pretty good. I do run a WATER2.0 on my rig which handles this just fine, but fans at max and it does make some noise, but not as bad as a Cascade LOL
    I would like to get to 5.0ghz and this looks like the cooler to get, but I need a new MB as I am stil using a Z68X-UD7-B3 which just works but has issues.
    So we have seen how the H220 stacks up against other sealed units. How does it stack up against a normal water cooling setup in the same price range of parts ?
    Admin
    Mar 2003
    North Texas
    I have been looking at the dual rad water coolers. This looks like a good one
    Not so crazy about the white fan blades
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    wow, this is nice. What are temperatures at example 1.4V in load with 4800 MHz? Could you test it for me?? Still very nice test! And if you have some AMD system, AMD part could be fun too. This AIO looks promising for me.
    ROG Power PCs - Intel and AMD
    CPUs:i7-6950X, i7-5960X, 4x i7-7700K, i3-7350K, 2x i7-6700K, i5-6600K, R7-1800X, R7-1700X, 3x AMD FX-9590, 1x AMD FX-9370, 4x AMD FX-8350,1x AMD FX-8320,1x AMD FX-8300, 2x AMD FX-6300,2x AMD FX-4300, 3x AMD FX-8150, 2x AMD FX-8120 125 and 95W, AMD X2 555 BE, AMD x4 965 BE C2 and C3, AMD X4 970 BE, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD X6 1100T BE, A10-7870K, Athlon 845, Athlon 860K,AMD A10-7850K, AMD A10-6800K, A8-6600K, 2x AMD A10-5800K, AMD A10-5600K, AMD A8-3850, AMD A8-3870K, 2x AMD A64 3000+, AMD 64+ X2 4600+ EE, Intel i7-980X, Intel i7-2600K, Intel i7-3770K,2x i7-4770K, Intel i7-3930KAMD Cinebench R10 challenge AMD Cinebench R15 thread Intel Cinebench R15 thread
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Thumbs up
    Thank you guys for the good feedback and good vibes , it took me 3 to 4 days to complete all the testing done, working on it night and day until the sun comes up sometimes , due to so many mounts and re-mounts of the water blocks and I did customized the H220 adding a vga MCW-82 7900 waterblock also , long hours really to gather all this data running prime 95 over and over again and again for long hours , over 300 pictures taken , 5 videos made , and to do the write up. I'm exhausted ,I need to get some sleep and get some rest.
    @Bill ( Buckeye ) - Sorry my friend I don't have water cooling set up that will match the price/performance of the Swiftech H220 on hand , hence I honestly and sincerely cannot provide a fair comparison as to how it stack up against similar priced custom water loops at that price range. Bill I am quite confident that you can get your cpu totally stable at 5.0Ghz using the Swiftech H220 , it can handle that and much more , but bare in mind your mile may vary due to the cpu and hardware used , the only way to know really is to test your hardware on the H220.
    @Ron ( runmc ) , hahahaha ... you can change the fan to the ones of your like , or perhaps get creative and use some paint and change the color of the fan , just kidding , do not paint the fans ,its not recommended
    @Flank3r I will try to do the test you are requesting later on tonight and will post the results for you here ,I only have one AMD cpu and mobo ( APU A6-3650 and a micro atx low end Biostar mobo that I used as a media center ) sorry I cannot test AMD for you.
    Xtreme Mentor
    Jun 2008
    France - Bx
    Great review chipsy ! I want one now
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Quote Originally Posted by FlanK3r View Post
    Here you go Flank3r as requested 4800Mhz 1.40v H220 ran in silent mode , no sweat for the H220. Hotest core temperature recorded running for 15 minutes Prime 95 Small FFTs wich it is brutal on a cpu was 79c wich peak twice only during the entire 15 minutes run , average all cores temperatures were 75c during the complete 15 minutes Prime 95 run , CPU with 4 cores 8 treads HT On 1.40v. Check out the video i made and look closely at the temperatures recorded min/average/maximum , bare in mind nobody would run Prime 95 Small FFTs all day long , so it is safe to say for 24/7 that is as stable as it can be 4800Mhz overclock than anyone using H220 can achieve and of course with much lower temperatures for day to day 24/7 use. Also bare in mind i have added an extra Video Card waterblock to the existing H220 loop with a hot running HD7970 heat monster while running this test , cpu and gpu on the same loop of the H220 ran in silent mode , i hope this gives you an idea what kind of Performance you can expect from the Swiftech H220. Im runnig 5000Mhz overclock now 100% stable Prime95 for 20 minutes with great temperatures fans on high mode highest core peaked only onced to 81c , safe to say 5000Mhz overclock it is also possible for 24/7 use on 3770K cpu using H220 with fans and pump in maximum speed wich is absolutly silent.
    Check it out here: http://www.youtube.com/watch?v=zD-0Z...ature=youtu.be
    Feb 2013
    Quote Originally Posted by chispy View Post
    Well, that decides it for me.
    Ordering one of these asap.
    May 2008
    Czech republic
    wow, is it awesome. Looks like the best allinone liquid? It could be perfect for my SR FX system in 2014 . I have one custom liquid, but Im so lazy to change it every 1/2-1 year with upgrade CPU (x6 1090T/x6 1100T/FX-8150/FX-8350/FX-83xx etc). So now I use H100, but this seems better and more quiet.
    Feb 2009
    In the video the temperature for the cpu appears to be around 70?C, whereas in your cpu-only review you describe the max temp as 80?C using the same overclock and load. How is it possible?
    Quote Originally Posted by NKrader View Post
    im sure bill gates has always wanted OLED Toilet Paper wipe his butt with steve jobs talking about ipad..
    Mini-review: Q6600 vs i5 2500K. Gpu scaling on games.
    Feb 2008
    Sydney
    Yea what prava said ^^^
    I'm a bit confused also.
    i7 2600K | Corsair H110 | Asus P8P67 Deluxe | G.Skill Ripjaws 8Gb | 670 GTX SLI | Corsair HX650
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Quote Originally Posted by prava View Post
    Im sorry , little mistake I made due to exhaustion of too many hours working on that review , those max 80c is with an MSI Lightning HD7970 added to the same loop and not the cpu only temperatures , got it fix for you , I hope you guys understand better the kind of cooling power this all in one closed water loop kit has even with an added VGA water block and a HD7970 when compared to a single cpu cooled cpu by a Thermaltake water 2.0 extreme.
  18. #18
    Oct 2008
    Lake Bodom
    Edit: Did you have any issues with the pump?
    Core i7 Extreme 4960X @ 4.5 GHz, Asus Rampage IV Black Edition, 32 GB Corsair Dominator GT DDR3-1866 MHz, GTX 780 3-way SLI, Corsair AX1200, Corsair 700D, Corsair H100i, Corsair Force GT 180GB, Windows 8 Pro, Asus VG278HR
    Core i7 Extreme 990X @ 4.4 GHz, Asus Rampage III Black Edition, 12 GB Corsair Dominator GT DDR3-1866 MHz, EVGA GTX 580 "Black Ops" SLI, Corsair AX1200, Corsair 650D, Corsar H100, Samsung 830 256GB, Asus ROG Thunderbolt, Windows 7 Pro
  19. #19
    Feb 2008
    I just ordered my Kit due to your Review. Thank you for showing us the ONLY real decent All-In-One Cooler currently available.
    The Photo's were superb and that mainly attracted me to it. Nothing better than having real sharp pics and avoiding any potato images.
    "If you haven't got anything nice to say about anybody, come sit next to me".
  20. #20
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Thumbs up
    @ xarot , Hi , I have no issues with the pump at all , in fact it is in use 24/7 , I do not turn off or shut down my pc for weeks. My Swiftech H220 still working flawlessly as day one , and that is with my MSI HD7970 Lightning in the same loop as my core i7 3770 overclocked at 4.6Ghz. If you have problems with the pump please contact Swiftech , they have awesome customer support and I am sure they will take care of you.
    @docwhom , thank you for the kind words , appreciated. You will like it a lot that's for sure. The cooper dual radiator and powerfull pump is enough for cooling one CPU and one VGA in the same loop .
    Kind regards: Angelo
  21. #21
    Admin
    Mar 2003
    North Texas
    H220
    In Stock
    UNDER THE ICE .com
    is the remedy
  22. #22
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Quote Originally Posted by runmc View Post
    H220
    In Stock
    ( out of stock ) *** (Update)*** In Stock again , hahahaha .... , Ron this things are selling out within minutes like hot cakes !
  23. #23
    Oct 2012
    There's a guy who replaced them with Noctua fans, I think NF-P12's?, and got a reduction in the decibles emanating from the radiator, as well as a dip in temps.
    Desktop rigs:
    Oysterhead- Intel i5-2320 CPU@3.0Ghz, Zalman 9500AT2, 8Gb Patriot 1333Mhz DDR3 RAM, 120Gb Kingston V200+ SSD, 1Tb Seagate HD, Linux Mint 17 Cinnamon 64 bit, LG 330W PSU
    Flying Frog Brigade-Intel Xeon W3520@2.66Ghz, 6Gb Hynix 1066Mhz DDR3 RAM, 640Gb Hitachi HD, 512Mb GDDR5 AMD HD4870, Mac OSX 10.6.8/Linux Mint 14 Cinnamon dual boot
    Laptop:
    Colonel Claypool-Intel T6600 Core 2 Duo, 4Gb 1066Mhz DDR3 RAM, 1Gb GDDR3 Nvidia 230M,240Gb Edge SATA6 SSD, Windows 7 Home 64 bit
  24. #24
    Dec 2004
    Long Island, NY
    What is the tube size to the gpu waterblock? It looks bigger. Do you have to change the fitting for that?
    I have the H220 and was wondering if this system was more than enough to cool my Haswell 4770 and GTX 780 when they are both overclocked.
    New rig: INWIN D-Frame, i7 4770k @ 4.7 Ghz/1.38V, Swiftech H220, MSI Z87-GD65 Gaming, Team Vulcan DDR3 1600, 9-9-9-24, Samsung 840 pro 256GB, EVGA GTX 780, Corsair 850W
    Old rig:Antec 900/GIGABYTE GA-X38T-DQ6
    E6750 @ 3.5 GHz/Thermalright 120 extreme/MX2
    CORSAIR Vengance 8GB
    PNY 8800GT/Thermalright HR-03 GT
    Old, old rig: FX-53/GIGABYTE K8NSNXP-939 nForce3 Ultra/1GB CORSAIR 3200XLPRO
    X800XTPE/WD 74GB Raptor/250GB Caviar
  25. #25
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Hi Rob94hawk , The tubing Dimensions 5/8" x 3/8 , the same tube dimension that comes with the kit , you can buy a few feet of tubing online in order to install additional Blocks or Rads , in the picture due to the angle of the camera it made it look bigger but is not , it is 5/8" x 3/8 black tubing. No you don't have to change the fittings for 5/8" x 3/8 tubing , I have rigorously tested and still running my H220 with the HD7970 Lightning since I made that review 24/7 pc without problems. Haswell is a heat monster after 1.30v for v.core so take that into account , I would test with the stock Radiator first add the GPU block and test , if if gets too warm for you I suggest installing another Radiator to the loop. I hope that answer your questions.
    Regards: Chispy
