Specifications:
The Box and the Package:
inside the box we found manual , warranty card, CD manual and Utility disk, Power adapter ,RJ45 Cable and two 5dbi antenna
The Router:
Here is the view of the router from the top where the indicators also located
the side view of the router
the front view
on the rear side , there are 1 x RJ45 for 10/100 BaseT for WAN, 4 x RJ45 for 10/100 BaseT for LAN , Power DC in , Reset Button and WPSButton.
next to the WAN Port there is a small switch where the user can switch the router from Router to Repeater to AP mode.
RT-N12 C1 Router Page:
Lets do the benchmark using Performance Test benchmark 7.0 over the 2.4Ghz Speed
the test took place on a small room , the router on table , and the distance was 30 meters away with 1 concrete wall..
