Sparky,
I ran into the exact same problem you did after adding the above app_info.xml from above post # 18.
The first download after adding the app_info.xml file and restrating the WCG software was perfect. The three remaining HCC WUs stayed and 97 new ATI WUs were downloaded & processed successfully. Following completion of the 97 WUs the program started working on the 3 old WUs. No new ATI WUs were auto requested. A manual attempt to download new WUs did not download any new ATI WUs. Shutting down the software and restarting it with the modded app_info.xml file still in it only yielded more old HCC WUs with no new ATI WUs.
I then removed the app_info.xml file and restarted the WCG software. I am now Back to two ATI WUs and 6 GPU WUs. Like you I am going to try to process the backlog of GPU WUs and then retry the app_info.xml file installation again.
Questions for OldChaps and the Gang:
1- The app_info thread list 3 versions of the app_info.xml file.
A- GPU only
B- GPU + GFAM
C- GPU + HCC
Which Version is the app_info.xml file located in thread # 18 above?
Should we be using GPU only?
Do we need to amend our preference on the WCG web site to restrict the download & processing to HCC ATI WUs only?
Your assistance is much appreciated,
Jean-Guy
