MSI GTX 660 testing
*so far I was testing the card with a review driver since Nvidia just released 306.23 today, which is meant to include the 660. The driver I was using seemed to have issues in older versions of DirectX ( 9 and below - as well as some shakiness in 10 ), For this reason I am retesting with the version that released today and will be updating this as I go along.*
For the current post I will post some pictures while I get some results re-ran instead of posting up pre-release driver tests.
The unit I have is an OC variant, with Afterburner I am able to get the card to its max for Unigine Heaven (DX11) and 3DMark11 @ a base/boost clock of 1118/1183 (MHz) and a memory clock to 1757MHz - this is over the stock 1033/1098 core and 1502 on mem. During the benchmarks that I was able to run with the pre-release driver I found it was happy chugging along at 1200MHz (a few ticks under1200 up to 1228 depending on the part of the scene)
Specs:
Product Name: N660 TF 2GD5(/OC)
Model: V287
GPU Codename: GK106
CUDA Cores: 960
Core Base Clock: 980 MHz (OC: 1033 MHz)
Core Boost Clock: 1033 MHz (OC: 1098 MHz)
Memory Clock: 6008 MHz (OC: 6008 MHz)
Memory Size: 2GB GDDR5
Memory Bus: 192 bits
Outputs: DisplayPort / HDMI / DL-DVI-I / DL-DVI-D
TDP: <150 W
Card Dimension: 235x125.2x35.8 mm
Form Factor: ATX
DirectX: 11
OpenGL: 4.2
PCI Express: 3.0
CUDA: Yes
SLI: Yes ~ 2-way
PhysX: Yes
PureVideo HD: Yes
3DVision Surround: Yes, 3 outputs per card
To be updated soon - will be a as soon as I can do it (Very Tired with a long night of testing done and more to do asap )
Test Results
I will be running many more tests - these are just the beginning - It does take a while to run each test a few times and do a lot of them for fine tuning card settings, edit them, make the posting easy to look at, and get rested for it again lol.
Stock @ 1033/1098MHz default base/boost 1502MHz memory
Max Overclocked Limits (stable) @ 1118/1183 default base /boost 1757MHz memory
Specifics: core voltage +100mV / power limit @ 110% / GPU Core offset @ +85MHz / memory offset @ +510MHz w/ auto fan
3DMark11 Entry @ Stock
3DMark11 Entry @ Overclocked Limit
3DMark11 Performance @ Stock
3DMark11 Performance @ Overclocked Limit
3DMark11 Extreme @ Stock
3DMark11 Extreme @ Overclocked Limit
Unigine Heaven
Basic DX9 @ Stock
Basic DX9 @ Overclocked Limit
Extreme DX11 @ Stock
Extreme DX11 @ Overclocked Limit
Moar tests on the way
