The SAS2308 is a faster clocked SAS2008, the SAS2308 supports PCIe Gen3, both are zero cache controllers.
In IT mode (passthrough) these are the best for ZFS and other OS's that do their own RAID.
In IR mode these controllers are as good as it gets with simple RAID (0,1 and 10)
Zero cache = you don't get write back, read ahead, Cached IO etc etc.
The only option you have is turning the drive cache on/off, with SSD's turn this off for better results.
Now the Extreme11 board has 2x PEX8747 PCIe bridges 16 lanes in and 32 lanes out each, these 64 lanes head of to the 4x PCIe 16x slots
Now the LGA2011 CPU has 40 PCIe Gen3 lanes, 32 go to the 2x PEX8747's, leaving 8 Gen3 lanes spare.
Now I can't be certain if all the 8 Gen3 lanes go to the SAS2308 or if other devices share lanes with it.
There are also 8x Gen2 lanes from the PCH, not sure how these are used either.
I do hope that the SAS2308 gets the 8x Gen3 lanes, even 8x Gen2 would be OK.
But if it only get 4x lanes then you will bottle neck as above.
There is a Datasheet on the Extreme11 board layout somewhere which has it drawn, can no longer find it.
LSI has the new P14 Firmware for the LSI9207 SAS2308 controller.
You should be able to update to this, as the onboard BIOS look the same as LSI's.
You will need IR firmware to have RAID.
You can upgrade to this via MSM in windows, load the Firmware then load the BIOS
Turn Diskcache OFF! in MSM, don't touch the Device manager Drive settings, default is king.
REBOOT for setting to take.
To help diagnose run a single drive test first, this is your base speed.
Setup a RAID0 array with 2 drives, REBOOT, get performance figures for this.
Keep adding a drive and do more tests.
At a certain point you may bottleneck, theoretically each drive you add should add the single drive performance.
Theoretically you should be able to get 8x ~500MB/s = 4TB/s
If the single drive speed is already slow then something is afoot, adding more drives ramp as slow.
When you get the speed sorted you'll be able to shift this to the eXtreme section
Would love to do a review on this powerhouse.
