Page 7 of 9 FirstFirst ... 456789 LastLast
Results 151 to 175 of 206
Thread: Ivy Bridge Temperatures Could Be Linked To TIM Inside Integrated Heatspreader: Report
  1. #151
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Quote Originally Posted by zerotol View Post
    so now we have tests concluding that removing the IHS works in lowering temps and removing the IHS does nothing at all and mounting on a naked core drops temps and mounting on a naked core does nothing.
    conclusion: we are right where we started, nothing conclusive can be decided.
    This.
    Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
    Quote Originally Posted by PerryR, on John Fruehe (JF-AMD) View Post
    Pretty much. Plus, he's here voluntarily.
  2. #152
    I am Xtreme
    Dec 2008
    France
    We had one test with people mounting their cooler directly onto the die (about the same temps, most likely poor contact), and two tests with people replacing TIM between IHS and CPU die with positive results. How is that not conclusive?
    Shamino backing this up:
    Quote Originally Posted by Shamino
    temps are not as good with IHS without exertion of force by ILM on the core but with good thermal paste and remounted IHS, temps are better and may bring the CPU to cold bug
    Donate to XS forums
  3. #153
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Quote Originally Posted by zalbard View Post
    When you write "most likely" in your conclusions, well, that's non conclusive. There have been quite a few test on the subject and the results are all over the place. Most of them don't say how exactly they're doing it, like "remounting" and stuff. A post with links to all of them would be nice. Or a comparison table, etc.
  4. #154
    Oct 2004
    So better check it yourself
    The Intel TIM is not that bad - compared to other thermal grease. I reapplied AC MX4 paste 3 times and twice the temps were worse. In the third run I did achieve the same temps as the Ivy had before...
    Then I used Liquid Pro and had more then 10° better temps.
    I think that thermal grease is optimized to work on surfaces with a defined/high micro roughness. Heat spreader and cpu cooler are rough - in contrast to the die. Therefore the very different temperature results we see. It just strongly depends on the thermal grease.
    And I would recommend to use liquid metal.
    If you can read German: http://www.hardwareluxx.de/community...l#post18877078
  5. #155
    c[_]
    Nov 2002
    Alberta, Canada
    Should try with no TIM, or as small of an amount as you possibly can use. Any reduction in metal contact area or pressure reduces thermal transfer capabilities. TIM's are an insulator most of the time..
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
  6. #156
    Nov 2006
    These posts saying "No AS5 without the IHS!!" make me lol. You can tell who the youngins are who never had to roll the dice with their Socket A mobile chips.
  7. #157
    I am Xtreme
    Aug 2008
    Quote Originally Posted by STEvil View Post
    but you use thermal paste right?
  8. #158
    Jun 2008
    Winter Springs, FL
    Why yes, yes I do use Koolance..*Flame Wall Inbound*
  9. #159
    Sep 2010
    Australia / Europe
    maybe this sounds ridiculous? but does anyone bother to also measure room temp at the time of the test? since different people carrying out different test in different regions and seasonal environments this can also affect results (only a little though unless your home is Antarctica and you're a penguin)
  10. #160
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Quote Originally Posted by WangChung View Post
    Or any socket A chip in general. None of them had an IHS.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
  11. #161
    Oct 2005
    SF Bay Area, CA, USA
    It looks to me that INTC is doing a poor job of applying the grease also. There putting way to much on. With thermal grease, less is more. Its really hard to find the right amount. Too much, too little is bad.
    RussC
    My Rig
    PII955-C2 3.8GHz, 2.5MHz NB
    GSkill 2x2GB DDR3-2400@900MHz
    M4A87T Antec 900 Case, Custom Mods x5Fans
    Custom Water Cooling: 15x12 3-Core Radiator
    4xSunon 4.5W Fans, DD12V-D5 Laing Variable Pump
    DD MC-TDX Water Block
    700W OZC ModX Power Supply
    GB HD6970OC2 Video Card
    2x150GB Raptor Raid
  12. #162
    Aug 2004
    Sweden
    Quote Originally Posted by Sparky View Post
    You got me. I had forgotten about my AQYHA 2500+ I used with AS5 and never had any issues.
  13. #163
    Aug 2005
    Austin, Texas
    I remember using AS5 on a delidded Opteron 170 with a Swiftech Storm
    7820X | Asrock X299 Taichi XE | Gigabyte 1080 Ti Xtreme | 32GB Memoriez | Corsair HXi1000 | 500GB 960 Evo
  14. #164
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    AS5... Ohh you new guys...
    AS5 wasnt on the market when socket A was launched... I didnt have Arctic Silver 5 before my Pentium 4 Northwood 800QDR, the 400 I used AS3 !!!
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
  15. #165
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by Hondacity View Post
    Generally the smallest dab I can manage more so to identify fissures and/or mounting issues. Beyond a couple microns most TIM's out there offer no appreciable heat transfer capabilities.
    and if you're still wondering: yes, I have run with no TIM at all, bare core or IHS.
  16. #166
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Cant recommend that on DIE directly, unless you want the DIE to die
    Killed a 3700+ because I was out of TIM and stores were closed,,, Patience didnt allow me to wait....
    TIM is good, but... I would agree, it might be time to buy some indium.... cutting a tiny bit and put it on DIE and squeeze down heatspreader, should make a noticable difference....
    Spectating;
  17. #167
    Oct 2003
    USA /okla
    wonder how good liquid metal would work vs AS5 ??
    i7 6700K @4.8 ghz
    XSPC RayStorm (very nice block)
    Z170 Sabertooh ,, 32GB- Gskill (15-15-15-36 @3600 mhz) 1:1
    XFX-7970 with Swiftech Komodo nickel block
    Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 700 rpm, Twin Vario mcp-655 pumps
    Samsung 850-1TB SSD,, OCZ ZX-1250W (powerfull and silent)
    Crossfire 30" decent monitor for IPS too bad SED tech died
    Docsis2.0 Docsis3.0
    -- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
  18. #168
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by M.Beier View Post
    Dont rock the boat (heatsink) and there should be no problem on die
  19. #169
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Was with a Dangerden TDX s939, those 2 screw mounting did not make things easy, no.
    Spectating;
  20. #170
    c[_]
    Nov 2002
    Alberta, Canada
    yeah, hoses put some serious torque on the water blocks making it twice as hard to keep them on the die flat..
  21. #171
    NooB MOD
    Jan 2006
    South Africa
    Who said anything about overclocking when they were launched? I still do S462
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
  22. #172
    Aug 2004
    Sweden
    Oh you new guys... only using AS5 with recently launched sockets.
  23. #173
    Jun 2005
    Madison, WI
    Quote Originally Posted by mibo View Post
    This.
    \Project\ Triple Surround Fury
    Case:
    Mountain Mods Ascension (modded)
    CPU: i7 920 @ 4GHz + EK Supreme HF (plate #1)
    GPU: GTX 670 3-Way SLI + XSPC Razor GTX670 water blocks
    Mobo: ASUS Rampage III Extreme + EK FB R3E water block
    RAM: 3x 2GB Mushkin Enhanced Ridgeback DDR3 @ 6-8-6-24 1T
    SSD: Crucial M4 256GB, 0309 firmware
    PSU: 2x Corsair HX1000s on separate circuits
    LCD: 3x ASUS VW266H 26" Nvidia Surround @ 6030 x 1200
    OS: Windows 7 64-bit Home Premium
    Games: AoE II: HD, BF4, MKKE, MW2 via FourDeltaOne (Domination all day!)
  24. #174
    Apr 2011
    Alberta Canada
    My toys...
    Asus X79 Deluxe | i7 4820K | Koolance CPU-380I w/Triple Rad/Swiftech Pump | RipjawsX 16GB 1866MHz | eVGA GTX 780 TRI-SLI | X-Fi Surround 5.1 Pro USB | Intel 530 120GB *2 RAID 0, Intel 510 250GB, Samsung 840 Pro 120GB, Samsung 840 500GB, Kingston V300 240GB | Corsair AX1200i | In Win D-Frame Orange | Win 8.1 Pro 64
    Asus Sabertooth Z77 | i7 3770K | NH-C12P SE14 | Vengeance 32GB LP | eVGA GT 240 | X-Fi Titanium Fatality | LSI SAS 9211-4i | Intel 330 120GB, Seagate 500GB *2, Samsung 200GB, WD 320GB *4 RAID 10, 500GB, Raptor 74GB | Antec TPQ-1200W | Corsair 650D | Win 8.1 Pro 64
    Asus Sabertooth P67 | i7 2600K | NH-U12P SE2 | Vengeance Pro 16GB 1866MHz | eVGA GTX 680 | Sound via HDMI | Intel 330 60GB, Samsung 840 Pro 120GB, WD VRaptor 300GB, 150GB *2 | Antec HCG-750W | Lian Li PC-60FNWB | Win 8.1 Pro 64
    Asus P8H77-M/CSM | i3 3220 | Shuriken | Vengeance 16GB LP | eVGA GT 610 | Sound Blaster Play | Hauppauge WinTV-HVR-1600 & HD PVR | Asus PCE-AC66 | Kingston V100 128GB, WD 1GB, 500GB, Seagate 2TB | Enermax Liberty 500W | Fractal Design Core 1000 | Win 8 Pro 64 w/Media Center
    Asus P8H77-M/CSM | i3 3220T | Hyper 212 Evo | Vengeance 8GB | eVGA 210 | Hauppauge WinTV-PVR-250 | Intel 330 60GB, WD 750GB, 250GB | Enermax Liberty 500W | Antec 300 | Win 7 Premium 32
    Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon Modified
  25. #175
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by solofly View Post
    I face-palmed at a couple of the guys posting there.. actually logged into [H] and replied lol. I feel dirty :p
