The display is a Noritake, but I think it has the controller built into its circuit board. I ended up using mine as an Aquaero LT when I screwed up the display on mine. I looked high and low for a Noritake with the same controller built in and could never find one. FYI, after my display burned out it was only a couple of months before it stopped remembering my settings, etc. So it may be that other problems eventually surface even if you're able to get a new display.
You might try contacting AC directly, or post on their forums
here.
Good luck; I hope you are able to get yours figured out.
