Results 1 to 18 of 18
Thread: I'm stumped.. pc boots in one house but not the other
    Fanboy of Good Products
    Oct 2008
    FL
    My buddy's PC will not boot at his house, it just hangs at the Windows boot screen. So he took it in to CompUSA and they told him it was a bad motherboard. So he bought one, brought it over to my house and we installed it. Cool, everything works. He takes it home and it does the same thing. He brought it back over to my house and it boots just fine. Obviously something is going on over at his house but we can't figure it out what it is. Anyone got any ideas?
    Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
    Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
    Cruncher #3: 8-core Xserve 1,1
    T400 for non-crunching
    "But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
    Xtreme Cruncher
    Nov 2008
    NE Ohio, USA
    He might not be getting proper voltage to his house or that outlet. If you have an available UPS with AVR, it's monitoring software it will tell you voltage coming into the UPS. Plus it will adjust the output voltage to what it should be, so if it boots then you know it's his lines. Or just get a voltmeter and test the outlet...and be carefull, no sparky
    24/7 Cruncher #1
    Crosshair VII Hero, Ryzen 3900X, 4.0 GHz @ 1.225v, Arctic Liquid Freezer II 420 AIO, 4x8GB GSKILL 3600MHz C15, ASUS TUF 3090 OC
    Samsung 980 1TB NVMe, Samsung 870 QVO 1TB, 2x10TB WD Red RAID1, Win 10 Pro, Enthoo Luxe TG, EVGA SuperNOVA 1200W P2
    24/7 Cruncher #2
    ASRock X470 Taichi, Ryzen 3900X, 4.0 GHz @ 1.225v, Arctic Liquid Freezer 280 AIO, 2x16GB GSKILL NEO 3600MHz C16, EVGA 3080ti FTW3 Ultra
    Samsung 970 EVO 250GB NVMe, Samsung 870 EVO 500GBWin 10 Ent, Enthoo Pro, Seasonic FOCUS Plus 850W
    24/7 Cruncher #3
    GA-P67A-UD4-B3 BIOS F8 mod, 2600k (L051B138) @ 4.5 GHz, 1.260v full load, Arctic Liquid 120, (Boots Win @ 5.6 GHz per Massman binning)
    Samsung Green 4x4GB @2133 C10, EVGA 2080ti FTW3 Hybrid, Samsung 870 EVO 500GB, 2x1TB WD Red RAID1, Win10 Ent, Rosewill Rise, EVGA SuperNOVA 1300W G2
    24/7 Cruncher #4 ... Crucial M225 64GB SSD Donated to Endurance Testing (Died at 968 TB of writes...no that is not a typo!)
    GA-EP45T-UD3LR BIOS F10 modded, Q6600 G0 VID 1.212 (L731B536), 3.6 GHz 9x400 @ 1.312v full load, Zerotherm Zen FZ120
    OCZ 2x2GB DDR3-1600MHz C7, Gigabyte 7950 @1200/1250, Crucial MX100 128GB, 2x1TB WD Red RAID1, Win10 Ent, Centurion 590, XFX PRO650W
    Music System
    SB Server->SB Touch w/Android Tablet as a remote->Denon AVR-X3300W->JBL Studio Series Floorstanding Speakers, JBL LS Center, 2x SVS SB-2000 Subs
    Dec 2007
    Earth
    May be the PSU. I had a situation where a customers PC would work just fine at my office, but would not boot past the windows loading screen at his house. We were stumped, and tried several things with many trips back and forth. I finally replaced the PSU and all was fixed. Only thing I could come up with for why it would work at my office and not his house, was his house power must have been too dirty for the failing PSU to cope with.
    Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
    Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
    QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
    DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
    Oct 2008
    FL
    That's actually a good idea. I'll see if we can't switch it out and see if that helps. He did take it over to his parent's house and it fired right up so it's definitely something going on at his house.
    c[_]
    Nov 2002
    Alberta, Canada
    PSU.. had a FSP unit that did that..
    All along the watchtower the watchmen watch the eternal return.
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    I'm tempted to suggest that before you spend money, try plugging a known good rig into the outlet at his house. In view of the fact that most psu's run on a voltage between 90 and 260v ish, if you have the means to, measure the voltage and then the voltage under load (any 1Kw and up load will do)
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    Oct 2006
    Shanhai China
    Sounds like an electric issue in the house, noise in the circuit, bad earth with a voltage running in it,phase problems. Or a simple lose wire in the plug you are using!
    24/7 PC CoolerMaster CM690 + 7 fans(its HOT as HELL in Shanghai) Intel Xeon E3 1230 3.3-3.7Ghz, 2x8GB DDR3 1600 G-Skill, HD GT630 2GB, Scandisk Pro 256SSD 2x2TB Green, 2x 3TB WD Green Data Drives. HTPC Q8400, EP45 UD3L 4x1GB Gskill6400, 1xWD Black 640GB,2x2TB WD Green, 2xWD 1TB Blue(RAID1), Sapphire 4530 512MB,
    Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.
    Mitch Ratcliffe, U.S. technology journalist and blogger
    Oct 2008
    FL
    Quote Originally Posted by STEvil View Post
    Well I have to admit we haven't tried a different psu at his house so that should be the next step.
    Quote Originally Posted by OldChap View Post
    I think I need to get a multimeter and go over and check the voltage. What should the voltage be anyway??
    Quote Originally Posted by chinaguy View Post
    While it might be bad circuitry i don't think it's a bad bad plug. We've tried two different power cords and several different outlets.
    Oct 2008
    FL
    double post because Lion+Safari is gay.
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    It should be 120v If you have one of those multi-outlet extensions like we have here then plug in and stick the multimeter prods in one of the sockets on the extension. next connect a load like a heater or an Iron, do you guys have toasters or kettles? if so one of those would do, then put the prods in the adjacent socket ....Voltage should still be 120v if not there is a problem that needs fixing sooner rather than later..
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    US voltage is anywhere between 110V-120V typically.
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    See how little I know
    Whatever the voltage is without load (in the range 110-120 then) it should stay the same under load
    Oct 2008
    FL
    alright we're gonna test it tomorrow, i'll report back. thanks guys!
    Oct 2008
    FL
    It was the piece of crap power supply. thanks guys!
    Xtreme Cruncher
    Dec 2008
    Los Angeles/Hong Kong
    And that means CompUSA is crap for pointing the finger to the motherboard...
    Team XS: xs4s.org
    Oct 2008
    FL
    Well the motherboard was bad too! I think the lightning strike fried both or something. It really was a mess that was difficult to figure out. But I got it
    Dec 2007
    Earth
    Quote Originally Posted by shoota View Post
    Just as I thought. Congrats on fixing it
  18. #18
    Oct 2008
    FL
    Quote Originally Posted by CrazyNutz View Post
    Thanks! You get an official XS thanks
