+ Reply to Thread
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 25 of 208
Thread: AMD Llano (desktop) reviews
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    210
    AMD FX-8350@5 GHz 1.52V + H100 Corsair, Crosshair V Formula-Z, 2x 4GB GSKill TridentX 2400 MHz+ 10-12-12-25, EAH HD6870 DirectCU, Corsair TX850W
    CPUs:next 2x AMD FX-8350, AMD FX-8320, AMD FX-6300, AMD FX-4300, AMD FX-8150, AMD X2 555 BE, AMD x4 965 BE C2 and C3, AMD X4 970 BE, AMD x4 975 BE, AMD x4 980 BE, AMD X6 1090T BE, AMD X6 1100T BE, AMD FX 8120 95W, AMD FX 8120 125W, next AMD FX-8150, AMD A10-6800K, 2x AMD A10-5800, AMD A10-5600K, AMD A8-3850, AMD A8-3870K, 2x AMD A64 3000+, AMD 64+ X2 4600+ EE, Intel i7-980X, Intel i7-2600K, 2x Intel i7-3770K, Intel i7-3930KAMD Cinebench R10 challenge
    Mar 2009
    37
    it is frustrating that amd's new highest end fusion chip performs like intel's i3-2100 with a $50 graphics card. but if they cost the same price, I guess that makes it sort of a deal. and you're right about the power. PCPER:
    "And if you take a look at the AMD A8-3850 compared to the Sandy Bridge based Core i7-2600K, it uses nearly as much power and it does not have a discrete GPU installed while the 2600K does. Despite the poor x86 performance of the A8-3850 APU it seems to be using a lot of power while falling behind."
    it remains to be seen if the price : cpu performance : gpu performance will work out so that a bunch of vendors buy this chip. It doesn't have much place with enthusiasts, even ones looking for an HTPC because of the power load. but maybe a niche will be found for it. maybe the price will be irresistible. "The AMD APUs are dirt cheap"
    PCPER: "Remember that we are talking about processors that cost a grand total of $135 or so and that includes your [quad core] x86 and GPU processing technology. For that dollar amount, the amount of gaming horsepower in the A8-3850 is truly an impressive feat."
    "I think in the coming months we will see much more success for Llano in the notebook market than in the desktop market with the exception of those budget minded users that like a little gaming on the site. "
    The only thing I can't swallow is the power load. How does that fit in with laptops. Urg.
    Jun 2006
    Space
    2
    looks like a pretty versatile chip. Cheap, runs games and does the everyday tasks that are required. It looks like it comes down to the simple question. Do you want to run games on this or 3D apps?
    If the question is yes, then it's an absolute steal. Intels option can't touch it at all. However, if you're just after encoding stuff, Intels wipes the floor with it.
    Jun 2002
    Ontario, Canada
    2
    Are the chips in stock anywhere yet? (North America)
    As quoted by LowRun......"So, we are one week past AMD's worst case scenario for BD's availability but they don't feel like communicating about the delay, I suppose AMD must be removed from the reliable sources list for AMD's products launch dates"
    Xtreme Member duron's Avatar
    Mar 2010
    Angeles/ HK/ Shenzen
    6
    Quote Originally Posted by freeloader View Post
    will start tomorrow here in HK but korea is already selling them
    Nov 2007
    0
    İnsane gpu power nearly 300 mhz oc thats damn impressive cpu part is sucky but that was no suprise lol
    Quote Originally Posted by LesGrossman View Post
    So for the last 3 months Nvidia talked about Uniengine and then Uniengine and more Uniengine and finally Uniengine. And then takes the best 5 seconds from all the benchmark run, makes a graph and then proudly shows it everywhere.
    Xtreme Enthusiast chuchnit's Avatar
    Jul 2008
    Prestonsburg, KY
    0
    Bravo to Hardware Canucks for having a wide array of processors in the charts. Anandtech's preview was a disaster and the review isn't very impressive either.
    Xtreme Member Spectrobozo's Avatar
    Jan 2004
    3
    overall it looks quite positive as expected... power consumption on the 3850 seems a bit high, but for a HTPC the 3800 would make more sense and fix most of that I think, but even so, considering the IGP performance I think the power consumption is low enough (idle power consumption looks very hard to be beaten by something like a i3 2100 + discrete graphics card, which would achieve the same performance)...
    what worries me so far are motherboards price... this platform needs some cheaper MBs, I'm talking about 60-70 USD.
    overclocking seems good, some 900MHz core + 2200Mhz+ memory clock IGP action must be quite interesting.
    but it's always a bit disappointing to see a newly released quad core being beaten even in heavily multi-threaded softwares in some cases by a dual core... but at the end what matters is the price/perf anyway.
    Feb 2006
    Vienna, Austria
    3
    Great review from Hardwarecanucks, while i was slightly disappointed with their latest tests their Llano review takes care of every advantage and disadvantage you get with and leaves no open questions
    Quote Originally Posted by Spectrobozo View Post
    Boards are reatiling for 60€ in central europe, fully featured boards start @70€ which is similar to 1155 boards
    i'm sure that A55 boards are going to start at 40€ once they arrive with the cheaper Llano models
    Core i7 2600k|HD 6950|8GB RipJawsX|2x 128gb Samsung SSD 830 Raid0|Asus Sabertooth P67
    Seasonic X-560|Corsair 650D|2x WD Red 3TB Raid1|WD Green 3TB|Asus Xonar Essence STX
    Core i3 2100|HD 7770|8GB RipJawsX|128gb Samsung SSD 830|Asrock Z77 Pro4-M
    Bequiet! E9 400W|Fractal Design Arc Mini|3x Hitachi 7k1000.C|Asus Xonar DX
    Dell Latitude E6410|Core i7 620m|8gb DDR3|WXGA+ Screen|Nvidia Quadro NVS3100
    256gb Samsung PB22-J|Intel Wireless 6300|Sierra Aircard MC8781|WD Scorpio Blue 1TB
    Harman Kardon HK1200|Vienna Acoustics Brandnew|AKG K240 Monitor 600ohm|Sony CDP 228ESD
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (HotWeather)
    100
    How far overclocking
    i5-2500K + Asus P8P67 Deluxe + Mushkin Blackline 8GB - 2133C10 (Hynix BFR) + Asus HD7970 DirectCU2 TOP + Samsung S22A300B
    EK SupremeHF + EK VGA HF + Swiftech 655 + XSPC ResTop + BlackIce GTX360 + LamptronFC2 + NMB-MAT 130CFMx3 Antec 1200W OC Version
    Compaq CQ20 / Lenovo Y450 / Note II / Tab Plus / iPhone 5 / iPad 3
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120
    Banned
    Sep 2009
    Past
    0
    Why in the hell anands boy put 16GB of 1866 slow cas ram in there ?! Anand is a joke .They start the article by saying that cpu is a disappointment , then the guy whines because he doesnt know how to overclock it.
    4x4Gb jesus, and they benchmarked it with it ,and power consumption too.
    Ian Cutrasses review on anand is beyond fail.He didnt even state which intel cpu he uses, (probablu 2500k).Gaming benchmarks are run on 5850 for some odd reason, even in crossfire.Therea are only two data points, two memory sets, but not described which used wehre and on which platform.Disaster.
    Jul 2008
    Prestonsburg, KY
    0
    Anandtech quality of articles suck nowadays. All of them.
    Devil kept pokin' slaveondope's Avatar
    Jan 2010
    South Kakalaky
    26
    OEM dream chip, agree Anand was -, Canucks did a very level headed review.
    Jun 2006
    Space
    2
    Quote Originally Posted by XRL8 View Post
    To be fair, I thought anands review was pretty decent. It's showing the same results as everyone else and well written. Not sure who Ian Cutrasse is, who you mention, or where that review is on Anands site. So I can't help there. I know anand's review the cpu was a 2105.
    Xtreme Mentor ajaidev's Avatar
    Jul 2008
    Shimla , India
    0
    I am plenty confused about pcper review in power consumption matters:
    These say that the difference between 2100 and A3850 in GPU burn is 42w and in CPU burn its 50W. Now the review of bjorn3d which states the difference of 19w and 7w respectively.
    http://www.bjorn3d.com/read.php?cID=2079&pageID=10742
    Yep something weird indeed. Also i have noticed a lot of reviewers using the old GTX 2xx series for the review lol whats up with that.
    The cpu seems good enough based on the reviews but its still more expensive for what it offers. I will wait to get it for the HTPC after the turbo cores also come why are they so late anyways? I hate AMD when they delay something without a real reason?
    I will however go ahead and get a llano based laptop asap that is if it shows up before Aug otherwise its 14r based i3 + 5650m for me "I know but its on sale"
    Coming Soon
    Banned
    Sep 2009
    Past
    0
    There are 3 Llano reviews on anand today, the one i was talking about is about asrock a75 mobo with llano and overclocking.
    its this one:
    http://www.anandtech.com/show/4478/a...o-overclocking
    Anands article while ok, still was missing alot.Like memory overclocking and more results.Im especially interested in IMC analysis+gpu performance scaling from the memory clock and latency side.
    overclocking Llano definitely boosts up performance in spite of the thing that asrock artictle on anand says (they claim theres a tdp wall)
    Jan 2011
    145.21.4.???
    1
    This is damn interesting.
    http://www.tomshardware.com/reviews/...o,2975-18.html
    More interesting is the fact that AMD’s Llano-based APU finishes the test before the Core i3 (despite the fact that Futuremark awards Intel a higher score), and only averages 4 W higher average power use. See? Those TDP numbers can be a little tricky when vendors don’t use the same methodology for rating their parts.
  18. #18
    Xtreme Mentor SKYMTL's Avatar
    Aug 2007
    9
    Quote Originally Posted by generics_user View Post
    Thanks for that and yes, I take full responsibility for a very small slide in the content within some of our reviews. The details of why this happened begin and end with my professional (no the site isn't my primary source of employment) and personal life taking up more time than I thought possible. I won't bore you with the details.
    I can however promise you that the hammer is back down.
  19. #19
    Oct 2008
    2
    It would be nice if it had a bit higher clocks and a nice turbo. A Phenom 965 is cheaper. And as it looks now with motherboard prices you can get an Athlon II 4X with a cheap mATX AM3 board and an external GPU for roughly the same money. And that's alot more flexible. And for a few bucks more it's even much faster.
  20. #20
    Aug 2007
    9
    Quote Originally Posted by ajaidev View Post
    From my understanding, there is no delay. The A6 3600 and A8 3800 should be released in parallel (or very close to) the non-turbo chips but I will admit that I've seen roadmaps placing them in Q3 2011. So there is some conflicting info out there.
    Ask and you shall receive:
    Quick GPU analysis
    Latency & Memory Speed Effect on IGP Performance
    Dual Graphics Performance
  21. #21
    Jun 2006
    Space
    2
    Quote Originally Posted by SKYMTL View Post
    I must say I'm waiting for the part on overclocking on your review. You seemed to indicate that there is some terrific gains from overclocking the memory and cpu quite aggressively.
  22. #22
    Oct 2008
    2
  23. #23
    Jan 2005
    7
    It seems like only xbitlabs authors put some effort to bench GPGPU. This is strange since according to AMD the GPGPU is one of the major selling points of Llano.
    Any way, surprisingly good idle power. Hybrid CF disappoints at this point. Good value - 135$ price points looks just right.
  24. #24
    Apr 2010
    0
    I think they used i3-2105, but I agree that review is horrible, the power consumption doesn't even state if it's CPU only or is it system power consumption.
    BTW did anyone compare the IQ in games? I've seen a post about Intel's GPU having lower IQ for better FPS.
    ________________
    Main:
    Phenom II x6 1090T BE|Crosshair IV Formula|Corsair 4x2GB DDR3|Sapphire HD5870|Adaptec 2405 + Hitachi Ultrastar 15k 450GB SAS, Toshiba MBD2147RC 146GB 10k SAS, Samsung F3 1TB, Seagate Barracuda Green 2TB 5900RPM, WD Black 2TB, Seagate Barracuda ST2000M001 2TB|Asus Xonar Essence ST + HD600|Corsair HX850|HPZR24w|Fractal Define XL Black|Windows 7 X64 Pro
    Backup/Storage server:
    HP Proliant ML350 G4|2 x Xeon "Nocona" 3GHz|4GB DDR1 ECC|Storage (SCSI): 3x10k 72GB + 10k 300GB + 15k 300GB + Ultrium460 tape drive|Storage (SATA): Adaptec 2810SA + 2 x WD Caviar 250GB RAID0 + Seagate 250GB|Windows Server 2008r2 Datacenter
    Other:
    HP Proliant DL380 G5|Xeon 5150|4GB FB DDR2 ECC|HP Smart Array P400-256MB cache|3x10k 146GB SAS in RAID 0 + 10k 146GB SAS|2x800W|ATi FireGL V7700|Samsung 226BW|Windows Server 2008r2 Enterprise
    HP DL320 G5|Xeon 3150 2.13GHz|1GB DDR2 ECC|2x80GB RAID 0|Windows Server 2008r2 Standard
    Laptop:
    HP 8560w|i5-2540M|2x4GB DDR3|AMD FirePro M5950|Samsung 840 Pro 256GB|Windows 7 X64 Pro
  25. #25
    Banned
    Sep 2009
    Past
    0
    Quick GPU analysis
    Yes your review seems to be more detailed , im eagearly awaiting OC results plus some analysis ,seems like llano overclocking is a harder one, IMC and memory OC would be welcome too .From what ive seen llano is capable of very fast memory speeds.
    Taking into account that llanos gpu is capable of very high oc from stock.Its reasonable to think that it becomes more memory starved too.So Doing a memory speed analysis at OCed cpu+gpu +some high mem speeds would be great too :P
+ Reply to Thread
