Hey everyone, I'm new here at xtreme systems and to overclocking. This is my first overclock and I don't think I did too bad, but like anything in life you turn too the pro's for advice. There are a lot of things in the bios I still don't really understand, hopefully you can help me out. My main concern is if the voltages are in a safe range, and any suggestions in general about tweaking any of the settings listed below, or any in general.
Thanks in advance
CPU = Intel Q9550 REV: E0
Motherboard = EP45-UD3P REV: 1.6
BIOS Version = FFb
Ram = Corsair Dominator 2x2GB PC2-8500 DDR2-1066 VER: 2.2
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .............: Auto
CPU Clock Ratio .....................: 8x
Fine CPU Clock Ratio ................: +0.5
CPU Frequency .......................: 3.82GHz
Clock Chip Control
Standard Clock Control
CPU Host Clock Control ..............: Enabled
CPU Host Frequency (Mhz) ............: 450
PCI Express Frequency (Mhz) .........: 103
C.I.A.2 .............................: Disabled
Advanced Clock Control
CPU Clock Drive .....................: 800mV
PCI Express Clock Drive .............: 900mV
CPU Clock Skew ......................: 0ps
MCH Clock Skew ......................: 0ps
DRAM Performance Control
Performance Enhance .................: Standard
Extreme Memory Profile (X.M.P.) .....: Auto
(G)MCH Frequency Latch ..............: 333MHz
System Memory Multiplier ............: 2.40B
Memory Frequency (Mhz) ..............: 1080
DRAM Timing Selectable ..............: Manual
Standard Timing Control
CAS Latency Time ....................: 5
tRCD ................................: 5
tRP .................................: 5
tRAS ................................: 15
Advanced Timing Control
tRRD ................................: Auto
tWTR ................................: Auto
tWR .................................: Auto
tRFC ................................: 50
tRTP ................................: Auto
Command Rate (CMD) ..................: Auto
Channel A
Static tRead Value ..................: 8
DDR Write Training ..................: Enabled
Driving Strength Profile ............: OC-1200
Channel B
Motherboard Voltage Control
CPU
Load Line Calibration ...............: Disabled
CPU Vcore ..........1.28750V ........: 1.32500V
CPU Termination ....1.200V ..........: 1.220V
CPU PLL ............1.500V ..........: 1.500v
CPU Reference ......0.760V ..........: 0.772V
MCH/ICH
MCH Core ...........1.100V...........: 1.200v
MCH Reference ......0.760V...........: 0.772V
MCH/DRAM Reference .0.900V...........: 0.900v
ICH I/O ............1.500V...........: 1.500v
ICH Core ...........1.100V...........: 1.100v
DRAM
DRAM Voltage .........1.800V.........: 2.100V
DRAM Termination .....0.900V.........: 0.900v
Channel A Reference ..0.900V.........: 0.900v
Channel B Reference ..0.900V.........: 0.900v
