I found this Vmod
do you think is correct?
has anyone tried this Vmod?
What value of VR should be used?
http://imageshack.us/g/88/hd4850gs09.jpg/
I found this Vmod
Crystal ball anyone?
I don't mean to sound rude, but if you don't know anything about the mod, but you have the card, why not post some pics yourself and then we'll see what can be done about modding it. Maybe you could even learn something.
Let me get this straight...
The pics show your actual card? So, you already did a mod without knowing if it was OK? And now that you have done it you thought asking about it would be a good idea? A little strange in terms of chronological order, but whatever.
The pics unfortunately are useless. As long as I don't know what the voltage controllers/opamps or whatever used are, I won't be able to help. Without detailed info I won't be able to help.
this is my vga
http://imageshack.us/photo/my-images...sc02518qw.jpg/
All I'm going to say is the following:
If you don't even try yourself, why should I continue to help you? You don't understand what I'm writing, fine then use a translater.
You are a funny guy. You want help, but you don't seem willing to provide even the most necessary info. Unless you change that, I'm out, as I have better things to do.
I wanted to know if anyone had tried the vmod!!
If you have not tried then why reply?/
thanks
People here have knowledge about the voltage regulators often used on these cards. I do not.
You need to post pictures of your actual card, the one you own in your hands. Give us close up pictures and you will find help.
That is all the other person was saying. The pictures you gave from the internet are too small and unreliable.
Smile
why are you trolling people trying to help you?
that is almost asking for people to say " you, go find it yourself"
I intentionally left the quoted question out when trying a last time to give some advice.
But now all that comes to mind about
is: Prove me wrong! And I honestly mean it.
It must either be the language barrier, or you still didn't understand yet that if you want help, you have to earn the favor by at least asking in a nice manner. The latter doesn't really seem to fit you.
I try disable OCP and i short resistor like on your picture and OCP is not disable
Please help me my soviet friend
No volts, no nothing
[SIGPIC][/SIGPIC]
My problem is OCP in idle i set 1.5v on GPU and work fine in idle on load black screen. In load 1.4V 1.42max all over i get black sreen and 0V on GPU
[SIGPIC][/SIGPIC]
Hmmm... I have 4870 palit sonic whith NCP5388 and i don't have OCP problem. 1060mgz&vGPU=1,55v (subzero cooling)
NCP5388 datasheet pin13 = ILIM, pin 12= ROSC
(ILIM)Over current shutdown threshold. To program the shutdown threshold, connect this pin to the ROSC pin via a resistor divider as shown in the Applications Schematics. To disable the over current feature connect this pin
directly to the ROSC pin. To guarantee correct operation, this pin should only be connected to the voltage
generated by the ROSC pin – do not connect this pin to any externally generated voltages.
I know that, definitely must check they are connected
[SIGPIC][/SIGPIC]
