Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: [Sweclockers] EXTRA: Problems with Sand Force 2 - withdrawal in sight
    Mar 2008
    Sweden
    After numerous reports of failing SSDs with control circuits from the series SandForce 2 speaks of a total withdrawal of all the models.
    With Intel's chipsets feldesignade for Sandy Bridge in recent memory, it looks like the computer world suffers another serious case of defective components. This time, the SSDs with the control circuits from the series Sand Force 2 who are in the spotlight after numerous reports of failing units.
    Users in particular SweClockers forum talks about SandForce 2-based storage devices that suddenly stop working. Symptoms vary from Bluescreens in Windows that the device no longer detected by BIOS. The common denominator is that there seems to be no apparent solution to the problem.
    Now, say sources SweClockers that SSDs with SandForce 2 sold topped and it can speak of a total withdrawal of all the models. Possible candidates are Corsair Force 3 and OCZ Vertex 3, but exactly which units these are is still unknown.
    The news updated as more details become known.
    11:45
    Corsair Force 3 120 GB sold topped the Swedish stores. (The only Corsair unit delivered in large volumes)
    13:46
    As it stands now is the Corsair Force 3 120 GB which is withdrawn. OCZ "working with Sand Force" to correct similar problems with Vertex 3 of the firmware
    16:16
    To clarify: OCZ withdraws no SSDs.
    Source
    Translated source
    EDIT: I just found this in the OCZ forum regarding BSOD and vertex3,agility3 or solid3
    There are way to many goal posts moving around to nail this issue down. To date, 1st June 2011, SF have not been able to reproduce any of the issues you guys are seeing..reason? I think its setup not FW causing you all issues.
    So...its time to fix the goal posts, we all test and report on our systems 1 way and 1 way only.
    1 absolutely NO OVERCLOCKING..why? it turns off power management features and has documented problems with power management especially on P67 and higher chipsets.
    2 You will be testing with a fresh install and your board needs to have been flashed to the newest UEFI or Bios available and it must have seen a thorough cmos clear.
    3 You have to set up windows 7 exactly as I document it here and report info exactly as I ask you do..this info then will go back to OCZ and SF as needed.
    I'm not interested in people who are imaging drives, don't moan at me, you want to test you test my way or you sit and watch, simple as that. If you overclock you MUST set systems to defaults, this includes ram and cpu and video...there are too many variables that get changed when the systems are overclocked and frankly we can not warrant a drive if its failing because the boards are doing something weird when overclocked...thats a problem for the motherboard manufacturer not OCZ.
    So...what to do.
    people with Intel based boards and vtx3/agility3 or solid3 and bsod look in here
    Asus P8Z68 Deluxe / i7 2600K / 2x4GB G.Skill RipjawsX 1600C8 / EVGA GTX 580 SC SLI
    Asus Crosshair V Formula-Z / FX8350 / G.Skill TridentX 2400C10 / GTX690
    I am Xtreme
    Dec 2008
    France
    Wow... I knew a few people had issues, but I had no clue about the scale...
    Donate to XS forums
    Xtreme Mentor
    Feb 2009
    Should have happened a while back.
    Mar 2008
    Sweden
    So...what to do.
    No OC with a Intel board and a OCZ Sandforce controlled SSD
    May 2006
    Again, this all has to do with firmware 2.06. I have had Vertex 3's running absolutely rock-solid and fast for 2 months now @ 4.8GHz. The key being I never "upgraded" to fw 2.06.
    The 2.06 firmware is flawed in it's hit n miss, flaky compatability. I'm not downplaying this at all - it's of monumental embarrassment for SF and any vendors that sell SF 2xxx SSDs.
    Sandforce is to blame for the broken firmware. How the problems are being handled can be blamed on the vendors (OCZ, Corsair) that have marketed, sold and supported the products.
    It's going to take SF's reputation years to recover from this one - especially since their last gen products weren't exactly problem-free.
    MAIN: 4770K 4.6 | Max VI Hero | 16GB 2400/C10 | H110 | 2 GTX670 FTW SLi | 2 840 Pro 256 R0 | SB Z | 750D | AX1200 | 305T | 8.1x64
    HTPC: 4670K 4.4 | Max VI Gene | 8GB 2133/C9 | NH-L9I | HD6450 | 840 Pro 128 | 2TB Red | GD05 | SSR-550RM | 70" | 8.1x64
    MEDIA: 4670K 4.4 | Gryphon | 8GB 1866/C9 | VX Black | HD4600 | 840 Pro 128 | 4 F4 HD204UI R5 | 550D | SSR-550RM | 245BW | 8.1x64
    Xtreme X.I.P.
    Apr 2008
    Norway
    Terrible story for all parties, it's not news exactly though...
    Almost all shops in Norway have pulled Force 3, Vertex 3 is still in stock though.
    I guess Corsair was hit the hardest as I expect all or most of their drives were at FW 2.06.
    Hardware:
    Jan 2009
    Italia
    crucial/intel rulez
    i have an M4 128gb and with a fresh install and the latest intel storage driver i do not have a single issues.....
    this afterall a trotthled agility and vertex3 120gb....
    crucial is the winner of these bad ssd situation....
    Xtreme Mentor
    Feb 2009
    It certainly seems that 2.02 is more stable BUT, if it was that stable why has back flashing been excluded as an interim solution?
    Its also hard to understand how these issues did not get picked up by any of the SF vendors that are supposed to test/valid the FW before release. Looking on the Corsair forum it is occurring on SATA 2 & 3 and a wide range of motherboards.
    SLC
    Oct 2004
    Ottawa, Canada
    Sandforce has been a mess from the very beginning. Too small of a company trying to do too much without proper testing.
    Xtreme X.I.P.
    Apr 2008
    Norway
    Quote Originally Posted by Ao1 View Post
    Beats me
    All my Vertex 3's on 2.02 are doing just fine and the one I did flash to 2.06 looks fine as well.
    The Agility 3 that arrived with 2.06 is flaky at best on P67/Z68, X58 looks fine though, strange...
    Anyways, they cant expect ordinary people to perform any tasks other than the normal ones before installing the OS onto their brand new SSDs.
    Hardware:
    SSD faster than your HDD
    Feb 2005
    Kalamazoo, MI
    Quote Originally Posted by Ghostleader View Post
    No OC during testing, if the method works for you, go back to overclocking.
    Please don't read into things that we are saying you can't overclock with an SSD.
    Just trying to get EVERYONE on a level playing field to find out where the issue lies.
    If XYZ (who doesn't overclock) has no stability on board PDQ, but then ABC with same board does have issues, it makes it hard to troubleshoot. Stock speeds makes for equal testing, then move on to restoring overclock and see if issue appears again, if not, then move on to next item.
    There really is something fishy going on with drivers and chipsets. We have already had cases showing this.
    Xtreme Mentor
    Feb 2009
    Doesn't seem to be a problem with Intel/Micron/Samsung/Toshiba etc
    Xtreme Mentor
    Feb 2009
    Whoa........
    CORSAIR FORCE SERIES 3 UPDATE, JUNE 7, 2011
    Over the past several days, we have analyzed issues associated with the stability of our recently released 120GB Force Series 3 SSD. Our review has identified that a significant percentage of these drive do not perform to specifications. The solution will require changes to both the SSD firmware and the hardware components of the SSD itself.
    We have stopped shipments of the affected drive, Corsair part number CSSD-F120GB3-BK, effective immediately and have implemented the following remediation plan:
    (1) ALL users should cease using the CSSD-F120GBG3-BK drive immediately, even if you have not experienced issues of stability.
    (2) Users may then either RETURN the drive to Corsair, at Corsair's expense, to be exchanged with a replacement drive that does meet specifications OR
    (3) Return the drive to their place of purchase.
    Corsair is committed to product quality and we want to assure our customers that this remediation plan will be implemented at no cost to you.
    To return your Force Series 3 120GB SSD to Corsair, contact Corsair to ARRANGE YOUR REPLACEMENT . Corsair will pay for shipping your drive back to Corsair and will replace your drive free of charge. Estimated turnaround time is ten business days.
    http://forum.corsair.com/v3/showthread.php?t=95825
    Xtreme X.I.P.
    Apr 2008
    Norway
    So, nothing on the 240GB.
    It does leave a lot of questions in the air though, anyways, Kudos for taking action.
    Hardware:
    SLC
    Oct 2004
    Ottawa, Canada
    Quote Originally Posted by Anvil View Post
    +1 Kudos for Corsair taking responsibility.
    Xtreme Mentor
    Feb 2009
    No choice I guess if there is a hardware issue involved as well. Boy this sucks for the whole SSD industry.
    Mar 2008
    Sweden
    @Ao1
    Nice find, I update the OP with it if you donīt mind.
  18. #18
    Apr 2004
    This is the very reason why I have been preaching Intel/Micron/Samsung/Toshiba everywhere I have posted. The Indilinx/OCZ/Sandforce/Jmicron do not have the testing capability the big boys have and with the number of different OS motherboards configurations, at least early adopters are bound to do the beta testing of the drives for the smaller companies until they fix their firmwares/hardware. This is the same story over and over again. The Indilinx Barefoot (Vertex), Jmicron, Sandforce (Vertex 2) and now Sandforce 2 (Vertex 3) all have had issues for months after market release with FW disappearing/ destructive reflash and what not required. If you care about your data, stick with the big name controllers until the small guys get their stuff figured out. Heck even the Sandforce/IMFT 25nm combination had problems just a couple of months ago and OCZ even snuck these drives on the market without P/N change.
  19. #19
    Xtreme Guru
    Aug 2009
    Wichita, Ks
    if there is a hardware issue then OCZ will probably follow suit with a recall as well. man that sucks for both companies. bad thing is some of these people buying SSD now for the first time, now that they are hitting somewhat of a mainstream status, are going to be turned off after this.
    Looks like the issue lies with SF imo.
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
  20. #20
    May 2006
    LOL!! The poop is hitting the fan for sure!!
  21. #21
    Xtreme X.I.P.
    Apr 2008
    Norway
    An official statement from OCZ
    Link http://www.ocztechnologyforum.com/fo...-manufacturers
    Hardware:
  22. #22
    May 2006
    Good for OCZ that they don't have to recall due to hardware problems... That'll help soften the blow.
  23. #23
    I am Xtreme
    Dec 2008
    France
    Good news for OCZ users. Hope the fix is coming soon.
    Donate to XS forums
  24. #24
    SLC
    Oct 2004
    Ottawa, Canada
    I, for one, do not believe that Corsair somehow messed up their SSDs and OCZ did not. It makes no sense because 95% of the complexity of the SSDs is in the controller and the NAND. The PCB itself (which is all the manufacturers have control over) is pretty damn straight forward and difficult to mess up. Additionally, Corsair and OCZ ssds are experiencing exactly the same issue. Seems pretty clear that the issue is in the controller and not in the PCB. Of course Corsair could have made a bad mistake I suppose, it is just unlikely.
    Just my opinion.
  25. #25
    May 2006
    Quote Originally Posted by One_Hertz View Post
    Just my opinion.
    Corsair is saying this hardware problem is ONLY affecting the 120GB version of their Force drive - their other Force/Force GT SF 2xxx SSDs don't have the same hardware problem. Yet, their other drives experience the BSOD issue, just like their OCZ counterparts. I think we're confusing a few things here, or rather, Corsair's announcement has introduced some further confusion into this mess.
