Results 1 to 14 of 14
Thread: [User-Review] Alphacool NexXxoS HD6970/6950-- GTX580/570 im Cartago´s Review
    Jan 2010
    Germany
    Thumbs up [User-Review] Alphacool NexXxoS HD6970/6950-- GTX580/570 im Cartago´s Review
    Alphacool NexXxoS HD6970/6950-- GTX580/570 im Cartago´s Review--Inexpensive but good?
    Hello and welcome to my new review.
    In today's review will have for you the brand new Alphacool GPU Full Cover,
    the NexXxoS ATXP ATI HD6970/6950 along with the matching backplate
    Alphacool, cool, after years of abstinence in the Full Cover GPU
    stalks tremble now with low prices the competition can.
    But unfortunately, the quality and cooling performance by this?
    I'm going to try to answer in this review.
    Good performance and cooler are available for this series of almost all of the leading manufacturers of water cooling,
    Unfortunately the prices are very high. Until now you had to spend 80 € for such a cool,
    because the price of the Alpha Cool is cool almost a bargain and is currently around 64 €.
    Some, such as CPU cooler is already much more expensive. The matching backplate
    is extremely cheap and far around 14 € the Back Platen other manufacturers require in terms of the award.
    Is the low price the only thing that has to ask the cooler?
    We'll see later in the review,
    But first I want to introduce the technical details of the cooler and the back plate:
    Technical details of the cooler:
    Material: copper, acetal
    Dimensions (L x W x H): 175 x 111 x 16mm
    Weight: 1000g
    thread: 4 x ¼ inch
    completely SLI / Crossfire ready
    included:
    1x Cooler
    Thermal pads
    Thermal Compound
    Mounting material
    2 x ¼ inch plugs
    multilingual (en. engl. FRA.) Installation instructions
    Even here, one is missing the really big weight of the cooler of around 1000g, and when used as cover by acetal.
    Technical details of the Backplate:
    Material: aluminum
    Color: black anodized
    Dimensions (L x W x H): 175 x 85 x 6mm
    Weight : about 168g
    The installation instructions are>here< zu finden.
    Lieferumfang:
    1x Cooler
    Thermal pads
    Mounting material
    Appearance:
    How do we get to see in later pictures, the radiator cap is black;
    the screw is copper and the Alpha Cool logo.
    Visually, it is not as massive as it actually is.
    The processing is where my present copy, good.
    No sharp edges or dirty drilled holes, the only thing that bothers me here
    are the long-running strip on the lid acetal.
    The machining marks in cooling block itself bother me, however not if they do not affect the cooling performance,
    what they do in this case is not, unfortunately, it can be seen in spite of vacuum packaging fingerprints of the workers,
    what is expressed in the same darker staining.
    The spacers are fixed to the heat sink
    and must not, for example. in the coolers of the EK, fixed difficulty with WLP.
    The thermal pads for memory chips have been designed
    only the need for voltage converter still be cut
    of course, is all over a small syringe of thermal compound on, but it is not clear who the manufacturer.
    The backplate also has stuck spacer and is
    in my case, clean processed, you are also tailored for thermal pads.
    And now the pictures:
    Testsystem and Test.
    Before I start my test, I will give you the first time the test system.
    System:
    -Grafik: PowerColor HD6950
    -CPU: Intel Core i7 860
    -Board: Asus Maximus III Formula
    -RAM: G.Skill Sniper (F3-12800CL9D-8GBSR2) DDR3-1600 CL 9-9-9-24 2T bei 1,25V
    -Netzteil: be-quiet! P9 850W
    -Case: CoolerMaster HAF-X
    -Betriebssystem: Windows 7 Ultimate 64bit SP1
    Water cooling consisting of:
    Alphacool HF 14 Yellowstone - Copper Edition
    Alphacool Alphacool NexXxoS ATXP ATI 6970/50 Serie + Backplate
    Phobya DC-12 400
    Alphacool Cape Corp AGB2 Black Rev. 2
    Phobya Nova1080 + 4x Phobya G-Silent 180
    Aquaero 5 XT als auslese gerät
    2 Phobya Temp. Sensoren IG/AG
    AC DFM HighFlow
    16/10 Masterkleer schlauch
    As a test program serves the ever known FurMark, version 1.9.0
    The resolution was set to 1680x1050 2xMSAA with the options:
    Dynamic Background
    Burn-in
    Xtreme> Burn-in
    Before the test I had the water preheat with Prime95, start at FurMark she lay at 25.6 °, and reached a maximum temperature of 28.9 °.
    The room had at the beginning of the test temperature of 22.6 °
    After the water temperature no longer rose, a screen of running FurMark and GPU-Z, Sensors rider would be made. In the GPU-Z I have the maximum temperature has reached the card in the test indicated.
    All information with + / - 1 ° as the tolerance value
    And these are the values ​​reached
    GPU-Z shows in the card 4 GPU temperatures and temperature for the voltage converter,
    and these are the values​​:
    GPU Temperatures
    GPU Temp. #1: 42°
    GPU Temp. #2: 42°
    GPU Temp. #3: 42,5°
    VReg Temperatur: 61,4°
    Beautiful, the cooler does exactly what he should do, he keeps the card cool. The area of the voltage converter that is really not on the condenser assembly is passed through directly, with ca.62 ° right cool.
    Flow:
    I have also measured the flow resistance and come to these Values​​:
    GPU cooling water circuit without 184.6 Lph
    Water circuit with NexXxoS 178.8 Lph
    Thus corresponds to the back of the radiator was circulated around 5.8 Lph.
    UPDATE GTX570 + Backplate:
    Now comes a test of a NexXxoS NVXP NV570
    At this point I save the description and start with the same technical details:
    Technical Details NV570:
    Weight: 1000g
    thread: 4 x ¼ inch
    Delivery:
    1x Cooler
    Thermal pads
    Thermal Compound
    Mounting material
    2 x ¼ inch plugs
    and Backplate:
    Material: aluminum
    Weight: ca 168g
    Compatible with AMD 580 / 570
    Delivery:
    1x Cooler
    Thermal pads
    Mounting material
    Unfortunately, even with these cooler lid acetal was not free from machine marks as you get to see in the following images:
    Let's get straight to temperatures
    I've had a surprise in terms of the original cooler.
    The surprise was that the card in FurMark
    been crashed regularly with the original cooler,
    and that once they have exceeded the 80 ° and the ladies and gentlemen went so quickly to control the fan on the map
    not turning up fast enough.
    itself:
    not even 1 minute. and the temperatures are already at 76 °
    And I have reached these temperatures with the NexXxoS NV570/580:
    Unfortunately, the GPU-Z shows only one GPU temperature, but think I should submit:
    GPU Temperatur: 42°
    Well here it shows how well the cooler actually is
    pity that the quality there's not as true as it should.
    At the conclusion change even the new found nothing
    Thus the conclusion is still time-variant but both.
    Conclusion:
    This time I miss the conclusion so easily.
    On one hand I am thrilled with the cooling power
    other hand, should Alphacool reloading in quality.
    Many would now say, "for the price it is all right, "
    may be the one that we see I do not.
    In particular, operates Alphacool a great effort to cool the
    to protect from discoloration, but it does not benefit if the worker
    in packaging has no gloves.
    The cooling capacity is as I said very good,
    because the cooler can very easily play with the big players in this industry.
    If the small quality problems in the course of the production is shut off,
    would be cool, at least for me, the best choice, especially since the price is really human.
    Since even the bottom line is unusual in two parts,
    I will also make the overall standings of the cooler.
    For the super-cooling capacity of the cooler the coveted „Cartago´s Review“ Award im Gold
    For the processing and quality impressions I forgive him, however, only the „Cartago’s Review“ Award in Silver
    Danksagung:
    I would like to especially Alphacool thanks for providing the test sample, the support and trust have placed in me, and the companyAquatuning,Asus, Intel, G.Skill, PowerColor, be-quiet!, und Masterkleer for their kind support.
    Jan 2010
    Germany
    as I am informed Thomas Alphacool breeding today is the quality with the next batch to be clearly better
    May 2010
    Any thoughts when this next batch will be released? I'm really interested in getting three of these to cool my 6950s. Thanks for the review btw
    -wermad
    i7 3820, Asrock Extreme11 X79, Corsair Vengeance 16GB, Quad MSI Lightning R7970, Samsung 840 250GB, Lepa G1600
    Case Labs TH10 (white), EK Supremacy CSQ, EK Ltg (x4), EK Monarch x4 (x2), Swiftech MCP35X, Koolance PMP-400 top + reservoir bodies, Black Ice GTX 480 (x2) & GTX 240, TFC X-Changer 480mm, EK XT-480mm (x2), Alphacool ST30 240mm, Cooler Master R4 green led fans (x52)
    Nov 2008
    Hmm. I always thought such machining marks were expected. Then again, I'm cheapo and use Dangerden Blocks.
    Mar 2006
    Sunny Lizardland
    Quote Originally Posted by Fatfool View Post
    DD blocks cheap? What day is it...?
    Components
    Case: Cooler Master ATCS840/ PSU: Seasonic X750/
    Mobo: Gigabyte GA-z68xp-ud4/ CPU: i5 2500k 4.2-4.8 GHz @ auto/
    VGA: EVGA GTX570 SC 940, 1880, 4500 @ 1.1v (Lucid dGPU)/ Memory: 8 Gb G.Skill DDR3 1866
    Storage: Corsair Force 3 120Gb SSD, Samsung 470 128Gb SSD, WD Scorpio Black 750 (Scythe Quiet Drive)
    OSs: Win7 HP x86_64/ Kubuntu 11.04 x86_64
    Cooling
    CPU: Koolance CPU-370/ GPU: Koolance VID-NX580/ Rads: XSPC RX360, Swiftech MCR-220QP/ Pump: EK-DCP 2.2 (softmount)
    Fans: 3x Noiseblocker m12-S1 @~500-750rpm, 3x Scythe GT 800 @~450-800RPM, Cooler Master 230mm (softmount) @300 RPM
    Tubing: 3/8" x 5/8" Primochill LRT (black)
    Fittings: Koolance compressions and 45/90 degree fittings
    Certified Quiet PC Loony
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    When was DD cheap??
    I think your thinking XSPC.
    Quote Originally Posted by warriorpoet View Post
    LOL id like to know too..
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    May 2010
    Can't seem to find DD 6970/6950 V1 blocks. I spent all my dough on my Sapphires so I need something inexpensive and works good. These seem to fit the bill and are not "plane-jane" looking like the xspc razors.
    Apr 2011
    North Queensland Australia
    Whoa, ACool still made GPU blocks?
    I still have one of their 9800 GTX Plexi monsters floating around
    -PB
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
    Nov 2008
    Quote Originally Posted by NaeKuh View Post
    When was DD cheap??
    Aren't Dangerden Blocks the el cheapo trashy kind that most people stay away from? (not many peeps using it even on XS)
    I mean, I got my Danger Den Radeon 5870 block when the 5870 was launched for 80 USD when other blocks were costing 110 USD (EK, Koolance) and up. It had a much simpler design with the flow bypassing the VRMs while more expensive competitors cooled the whole card
    May 2009
    Can someone help me with a compatibility list for the 6950 Version?
    Ω
    Jun 2009
    Brooklyn, NY
    Too bad that they don't have Nickel versions for the bling bling But good performance overall on the blocks.
    Nicely done review
    Ω Raven Build Blog
    "The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." - Thomas Jefferson
    " Inter Arma Enim Silent Leges" - In times of war, the law falls silent.
    Jan 2010
    Germany
    Quote Originally Posted by mav2000 View Post
    This coolers is compatible with
    PowerColor AX6950 2GBD5-M2DH
    Asus 90-C3CHD0-S0UAY0YZ
    Club3D CGAX-69548
    Gigabyte GV-R695D5-2GD-B
    HIS H695F2G2M
    MSI V803-691R
    Sapphire 21188-00-40R
    XFX HD-695A-CNFC
    __________________
    May 2004
    Aland Islands, Finland
    Quote Originally Posted by cartago2202 View Post
    Club3D CGAX-69548
    HIS H695F2G2M
    MSI V803-691R
    XFX HD-695A-CNFC
    __________________
    Hey cartago, can you use the stock back plate with this block?
    Asus Crosshair IV Extreme
    AMD FX-8350
    AMD ref. HD 6950 2Gb x 2
    4x4Gb HyperX T1
    Corsair AX1200
    3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
    Aug 2007
    Brasilia - DF - Brazil
    Quote Originally Posted by wez View Post
    No, you can't. I have two units and the alphacool backplate is not required but it seems to help avoid flexing the card.
    My Lian Li G70
    Asus P6X58D-E * i7-930 * Saphire 7970 * 6GB Corsair XMS3 1600 C7 * Crucial M4 256GB SSD * Lian Li G70W Powdercoated
    Watercooled by single loop Coolgate Quad 120 + Swiftech MCR220 with San Aces H1011 * EK Supreme HF * Koolance VID-AR797 * EK Asus X58 full set * DDC 3.25 with EK Dual Top/Res
