$15 Dollar diff which one should I get.Does the 1100t offer anything over 1090t other than that 3% clock raise.
1090T
1100T
Honestly, the week/year the chip was produced will probably tell you more about how it'll perform than the model number will.
If your going to buy it in a B&M store, where you can actually look at the production codes I'd say to check out this thread and
try to find a chip with a code that was produced in a strong week...
http://www.xtremesystems.org/forums/...d.php?t=250607
If your buying online I'd say to spend the extra $15 and go for the 1100T.
It should be binned better than a 1090T produced that same week.
It's all really luck of the draw in the end.
All you can do is try and narrow the odds.
AMD FX-8350 (1237 PGN) | Asus Crosshair V Formula (bios 1703) | G.Skill 2133 CL9 @ 2230 9-11-10 | Sapphire HD 6870 | Samsung 830 128Gb SSD / 2 WD 1Tb Black SATA3 storage | Corsair TX750 PSU
Watercooled ST 120.3 & TC 120.1 / MCP35X XSPC Top / Apogee HD Block | WIN7 64 Bit HP | Corsair 800D Obsidian Case
First Computer: Commodore Vic 20 (circa 1981).
If it's for 24/7 or 3D benching, the 1100T seems to be reaching better speeds. If it's for 2D benching, the 1090T is more popular and therefore worth more points on hwbot.
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
may be 1100T got better silicon bin?
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
waiting review the battle of this procs...
Ghz Was Not Everything.......
I see a lot of 1090T's beating my 1100T despite my 1100T being a 1045 batch with low SN
Those week 101x/102x 1090T's were awfully good.
I'm not sure if I will order future CPU's online unless they are used/tested already...considering I have a local computer outlet with about 400 CPUs in stock.
Smile
...that cant be the normal VID.
Smile
use the CPU-z screen for VID and turn off C&Q and turbo.
my guess is 1.325.
but it can change depnding on the motherboard you put it in.
OT
beep did you ever get that athlon tested?
Smile
Yep thats not the real VID that was reported, possibly the Turbo VID
Smile
What week and batch code did you end up getting?
from that last picture it looks like you are hitting a temp wall
find a way to lower your temps
Try with 4 gigs...that board is kinda weird with all slots filled
IIRC F8 was my favorite bios on that board, F9 and F9A/F9B were unstable for me, dunno how F10 bioses are but I sold my board to gomeler way back when...
Oh BTW that board has a NB hole somwhere
Smile
