does anyone know if any company will make chipset blocks for this board?
I think the EK-MOSFET ASUS 3a, EK-ASUS NB/SB 1 and EK-ASUS NB/SB 4 will fit. You should check their coolingconfigurator.com site
I doubt you will see many P67 blocks except for the MIV, UD7 and the WS since they use the NF200 chip which could use better cooling. My P67 doesn't really get warm even with heavy overclocking and use, so other than the bling factor, not sure what purpose it would serve.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
Source: http://www.mips-computer.de/
ASUS P8P7 Series Kühler Set Nickel POM
- ASUS P8P67
- ASUS P8P67 Pro
- ASUS P8P67 Evo
*waiting for Eddy to post now*
Circles SucQ!
Watercooled Murdermod Silverstone TJ07
Asus P8P67 Deluxe B3
Intel Core i7 2600K
8GB G.Skill DDR3 1600Mhz
eVGA 480 GTX SLI
8.5TB (1x Seagate 1TB 7200.12, 2x Hitachi 3TB, 1x Seagate 1.5TB 7200.11)
Corsair AX1200 PSU All Custom Cables
Westinghouse 24" 1920x1200
Windows 7
I was going to wait on my WC build because there wasn't any waterblocks for the P8P67 Pro but looks like that won't be happening haha
hmmm mannnnnnn MOAR BLOCKS@@@
any mips retailers in the US?
Intel Core i7 2600K
eVGA 480 GTX SLI
Windows 7
EK is started producing the MOSFET only block for P8P67 PRO, -EVO and vanilla motherboards. It will be very cheap, good looking and effective at it's job!
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
I know the answer will probably be 'no', but I'll ask anyway.
That block looks an aweful lot like the P7P55D kit. Any idea if this block is compatible with the Asus P7P55D boards?
Little expense had been spared to create the impression that no expense had been spared. - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
does anyone know if this blocks could fit in a P8P67M PRO mATX ?
ASUS 3a Mosfet block fits, according to their cooling configurator
yes that asus i already know, but that MIPS blocks its awesome.
i want know if in the mosfets will fit.
I assumed you reffered to ek. Mips one looks cool, but it seems to me that it will interfere with power/eps connector and chokes on ASUS P8P67-M PRO. I guess thats why ek went with two separate mosfet blocks (to maximize compatibility).
I saw some images of the motherboard layout and thats right the 8 pin connector its on the middle.
i will have to buy ek.
EK-MOSFET ASUS P8P67 series are out, available in Nickel Plexi and Nickel Acetal:
- http://www.ekwaterblocks.com/shop/ek...67-nickel.html
- http://www.ekwaterblocks.com/shop/ek...al-nickel.html
Best Regards,
Niko
EK Water Blocks R&D
ekwb.com
Waterblock looks like a boomerang
Worklog 1: ★★★ Project: Icebreaker ★★★
Bundymania @Facebook: Come and join me now
Triple (360) Radiator Roundup with 22 Rads !
Swiftech MCP35X Pump Review /// Roundup -> Bay Reservoirs & Laing Tops !
Review: 22 CPU Waterblocks // Review: 4x Tecnofront Reservoirs !
Quad Radiator Roundup - 11 Rads tested
Update: Mora 2 / Mora 3 / Phobya 1080 Xtreme & Supernova 1260
Tubing Comparison: 3/8" & 5/8" from Masterkleer, Primochill, Tygon, Kooolance, Nalgene
@jumper2high:
@bundymania: Haha, Aussie edition block?
EK Water Blocks R&D
ekwb.com
