Seems evident that upgrading to SB from i7 will bring close to no improvement in gaming experience core for core. Other things though, encoding, etc its a fine upgrade. Plus the power consumption is awesome.
Gigabyte Z77X-UD5H
G-Skill Ripjaws X 16Gb - 2133Mhz
Thermalright Ultra-120 eXtreme
i7 2600k @ 4.4Ghz
Sapphire 7970 OC 1.2Ghz
Mushkin Chronos Deluxe 128Gb
Interesting results. Looks like great improvement in power draw and a much less impressive improvement in IPC(i skimmed over the numbers,it goes from 0 to 25%,mostly hovers under or near 10%;on average ~7% improvement,solid but not impressive). I guess AVX will change things a bit,but we will have to wait for the optimized software.
Why haven't they tested the iGPU or am I missing it somewhere?
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
I wish they compared it to other processors as well like the 1366 CPU's. Meh, 1155 doesn't really look like an upgrade for X58 970/980x users.
AMD Threadripper 12 core 1920x CPU OC at 4Ghz | ASUS ROG Zenith Extreme X399 motherboard | 32GB G.Skill Trident RGB 3200Mhz DDR4 RAM | Gigabyte 11GB GTX 1080 Ti Aorus Xtreme GPU | SilverStone Strider Platinum 1000W Power Supply | Crucial 1050GB MX300 SSD | 4TB Western Digital HDD | 60" Samsung JU7000 4K UHD TV at 3840x2160
LoL.
970 and 980X are HexaCores and the X58 is High-End and P67 (or LGA1155) is Mainstream with QuadCores.
That would be a downgrade for 970/980x.
Upcoming SB is not high-end, and won't compete with 6C/12T 32nm CPUs. It will be interesting to see if it can affect the price on these. But these numbers (specially the power usage/heat) shows that it will make sure that all 45nm become antic soon.
► ASUS P8P67 Deluxe (BIOS 1305)
► 2600K @4.5GHz 1.27v , 1 hour Prime
► Silver Arrow , push/pull
► 2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
► GTX560 GB OC @910/2400 0.987v
► Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
► CM Storm Scout + Corsair HX 1000W
► EVGA SR-2 , A50
► 2 x Xeon X5650 @3.86GHz(203x19) 1.20v
► Megahalem + Silver Arrow , push/pull
► 3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
► XFX GTX 295 @650/1200/1402
► Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
► SilverStone Fortress FT01 + Corsair AX 1200W
but think, they tested without activ turbo2.0, right?
ROG Power PCs - Intel and AMD
I wonder what cpu they have tested. I thought CPU-Z is already able to detect SB correctly.
http://www.awardfabrik.de/forum/show...6&postcount=53
Any way, 2.8GHz is not a native freq of i7-2600K so I don't sure what turbo they tested exactly.
from earlier leak, the IPC is about 10% increase clock to clock. But what is interesting about Sandy Bridge is AVX and power consumption.
Main Rig:
Processor & Motherboard:AMD Ryzen5 1400 ' Gigabyte B450M-DS3H
Random Access Memory Module:Adata XPG DDR4 3000 MHz 2x8GB
Graphic Card:XFX RX 580 4GB
Power Supply Unit:FSP AURUM 92+ Series PT-650M
Storage Unit:Crucial MX 500 240GB SATA III SSD
Processor Heatsink Fan:AMD Wraith Spire RGB
Chasis:Thermaltake Level 10GTS Black
but..clocks to clocks is not big diference (without turbo), whats great is power consum. in load ! Awesome.
yeah, but if they used the voltage as in the CPU-Z screen showed (1.32v) then is the measurement incorrect.
I had told you all about how important power saving and turbo will be on SNB long time back the IPC improvement what ever it formulates to is less important i was told that IPC is less important and Intel wanted to use combination of Turbo power saving and the process manufacturing to attract the costumers, i did not expect anything over 5-7% improvement in IPC from 1156 to 1155.
Coming Soon
shockingly the ipc gains were not much at all
and the turbo tests showed almost no difference (SC2 should have seen much more than just 4.3%)
and power consumption is hard to compare due to the fact they compared it while overclocked, against another overclock. and they didnt mention if they had to adjust voltages or not on the 875K, which would make a massive difference. just going by the charts 229W - 89W = 140W difference between idle and load. so did they really have to make the 875K a 170W TDP cpu just to reach 3.4ghz?
2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
XS Build Log for: My Latest Custom Case
Nice, but I would prefer more info about S2011 CPUs.
Anand's review showed much better improvement that what this review is showing. didn't overclocked 2400k in Annad's review almost match the i980x ?
if this review is true, then there hope for bulldozer
it depends on how the K model overclocks.
5ghz reachable or close by, well then its a given.
4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
do we know the max speed for the non K models yet?
