problem with ek block screws.
i buy 10 screws 10mm for used.
Guys,just wanted to say if you have a MCW60 swiftech block and a GT200 plate for it , you can drill new holes on it,to mount on a reference GTX 460 Measure carefully and be very cautious not to over tighten,just tighten enough to hold it in place ,again it is very important not to over tighten.
My Heatware
Originally Posted by some guy on internet
That's your problem right there. Just forget about how things look on paper as that's irrelevant.
MfG, Guapa
Guapa's Layout-Finder *** Wieviel Wärme gibt eine Pumpe an das Wasser/Umgebung ab? *** Übersicht: Softwarebasierende Überwachungsgeräte
nVidia Geforce - Wakü-Sammelthreads:
GTX 4XX *** GTX 560 Ti & GTX 590 *** GTX 570 & 580 *** GTX 670 *** GTX 680 *** GTX 690
Just ordered a card. will have it sent to DD for a block
"Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
Make sure its a reference design
| Completed: Project "Simples" | Custom TJ07 | P67A-UD3 | 2600K | GTX460 | MCR320+MCR220 | DDC 18W+XSPC Res |
| In progress: Project "Weebeastie" | A70B | P6T7 WS | i7-970 | 4xGTX470 | PA120.3+RX240+TFC120 | XSPC Dual-Pump-BayRes |
| In progress: Project "Gemini" | PC-P80B | EVGA SR-2 | 2xX5650 | 7100GS | PA140.3 | EK DCP-4.0 |
why even bother get FC for 460. with added block price you can get a 470 or 5870. if you just want cool and quiet, the 460 already cool and quiet.
The MSI Hawk has a sweet stock heatsink that I'd almost never take off...
Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
I just received my EK FC-GTX460 yesterday:
A 90º Rotatory and an EK Compression Fitting will be his friends.
I will put it on a MSI Cyclone OC GTX460 1gb:
HEATWARE
x58-UD5 ▀▄ i7 950 4.0Ghz ▀▄ ZOTAC GTX 580 ▀▄ Mushkins 1600Mhz
any compatibility issues between GPU 220/210 and gigabyte GTX 460 1gb version?
