Hi all,
I just bought a complete new pc with the idea of watercooling everything.
Now it seems like they delivered the wrong videocard:
a Gigabyte GV-R587UD-1GD (non reference) instead of a Gigabyte GV-R587D5-1GD-B (reference)
although I am 100% sure I ordered their last D5, it seems like the webshop "corrected" it into the UD quite early. Cause in the order confirmation, it already sais UD (looked over it)
So actually I have no proof of them delivering the wrong card
In a way this should be "ok", since this UD card is one of Gigabytes Ultra Durable series (2oz copper, japanese solid capacitors, tier 1 Samsung/HYnix memery, lower RDS mosfets, ferrite core / metal choke), but because this is a non reference design I probably wont be able to attach the EK waterblock on this card
so I just did some research and found the following about Gigabytes UD (thx to infra1 on [H]ard forum for the images):
as you can see the heatsink only cools the GPU itself and not the RAM and ?VRMs?
About the reference design, I found the below picture:
As you can see the reference design cools the GPU, the RAM and the ?VRMs?
So I was wondering what your expert advice on this is
Should I just keep and watercool only the GPU (would my ancient nVidia 6600GT maze4 fit on this?)
And then buy some heatsinks for the RAM (should be findable I guess? But where and what advice is very welcome)
Finding sinks to fit on the ?VRMs? (it are VRMs, right?) will probably be harder, so advice on this is also very welcome... And does anyone have an idea where they are on the UD5? Is it beneath that mini heatsink, 3th row right from the right RAM?
Or would you say that this isn't worth the effort and I should just try to get an exchange (which probably takes months to get in stock)?
Thanks for the advice
Masta
