Results 1 to 11 of 11
Thread: High CFM 140mm fan
    Jul 2006
    High CFM 140mm fan
    Anyone know, outside of Scythe (darned sleeve bearings failing ) and yate medium speed, what kind of 140mm fan offerings there are. I would love to have a 100-130CFM 140mm fan for my top exhuast on my Antec 300.
    eXt 4
    Intel Core i5 2500k @ 5GHz | Asus Maximus GENE-Z | Corsair Vengence 16GB DDR3-1600 9-9-9-24 | eVga GTX 580 SC 1000/2300 | SeaSonic Platinum Platinum-860 | Corsir Force GT 60GB/WD Green 1.5TB
    XSPC dual bay res w/ Laing D5/ XSPC Raystorm CPU Block / EK-FC580 GTX+ GPU block / XSPC RX240 / XSPC RX360 / All Yate D12Sm-12 Fans / NZXT case
    St0rage
    AMD Phenom II 965 @ 3.6GHz | Gigabyte MA785G-UD3H | Corsair XMS 8GB DDR2-1066 | 785G integrated | Corsiar TX 750 | WD Green 2.0TB
    Thermalright VenomousX, ALL Yate D12SL-12 FANS
    Jan 2008
    The scythe slipstreams fail a lot? I was just about to order some.
    Modded Cosmos. | Maximus II Formula. Bios 1307| 2x2 Mushkin XP ASCENT 8500 | Q9550-E0- 4.10 + TRUE | Visiontek HD4870X2 | LN32A550 1920x1080 | X-FI Extreme Gamer | Z5300E | G15v.1 | G7 | MX518 | Corsair HX1000 | X25-MG2 80G | 5xHDD
    ____________________________________
    Quote Originally Posted by saaya View Post
    most people dont care about opencl, physix, folding at home and direct compute... they want cool explosions and things blowing up and boobs jumping around realistically... .
    Sep 2008
    This Koolance fan delivers 91.2CFM:
    http://www.performance-pcs.com/catal...2e15882ab85745
    Feb 2007
    why do you need such a high airflow for the top exhaust? you would do just fine with a fan that has half of what your looking for in cfm
    Nov 2009
    Portugal
    You can choose those Noiseblocker's PK-3
    Highspeed: < 153 m³/h (90 CFM)
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    If you insist on a high speed fan then if you can find a vendor.... http://www.yateloon.com/style/conten...=8511&id=38839
    You might want to check out psu fans...they tend to run faster. Ikonic and corsair psu's have the 140cfm yateloon I think
    Same rules about finding one but the absolute top I've seen to date is a 24v EBM Pabst http://www.ebmpapst.us/aTCA/New%20Co...for%20atca.pdf the 5300TDH3 provides 390 CFM at 9000 RPM, and 300 CFM at 2 in. of H2O.
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
    Nov 2009
    New Jersey, USA
    Not surprised about the sleeve bearings. Up seems to be the problem with most 140mm fans. Whether it's the Kaze Maru 1900RPM (an otherwise wonderful fan) or the Evercool Red Scorpion (supposedly has sealed fluid bearings), pushing air up seems to be a real problem for these fans.
    The only 140mm fan I have that has no problem with up is the Noctua P14. Newark has some 140x51mm 12v DC fans from Pabst and Sanyo Denki, but they are pricey and thick, and probably move a lot more air than you need to move.
    Hotrod: Core i7 860 22x182 4GHz Vcore 1.3125v | Noctua NH-D14 w/ P14 + 2 x AP-14's
    Gigabyte P55A-UD3P f13 | 4GB Ripjaws DDR3-2000 @1820MHz | Gigabyte HD 4670 1GB
    Kingston V+ 64GB SSD + Barracuda 1TB 7200.12 | NZXT Beta Evo | Seasonic X-650
    Nov 2009
    New Jersey, USA
    Koolance and Lian Li fans from here have ball bearings. There is another here. I don't know if any of them would push enough air for you, though.
    Jul 2006
    None of the fans, except high speed yates which are impossible to find, are worth upgrading my Antec fan for. I have my venomous blowing heat up and out of my case, so using a high speed 140mm fan would be the best choice. However, I may end up buying a 120-->140mm adapter and mounting another delta AFB1212.
    eXt 4
    St0rage
    Nov 2009
    New Jersey, USA
    You may have the right of it. I just yesterday received a MASSCOOL SLC-FD14025 Supper Silent Case fan 140X140X25MM 2 BALL BEARING FAN GUARD and CONTROL BRACKET (hows that for a mouthful?). It has a really fine enclosed-circuit fan controller. It has a 140mm grill (first one of those I've seen). It has four double-ended fan mounts. But it hardly pushes any air! Bah!
    Here is a 1400RPM 140mm YL fan.
    I can't find the D14SH or D14BH anywhere.
    Feb 2008
    Ca
    Quote Originally Posted by ehume View Post
    These have been for sale for at least a year FYI!
    http://www.jab-tech.com/140mm-Black-...l-pr-3620.html
    http://www.jab-tech.com/140mm-Chrome...l-pr-3621.html
    Haswell, Maxwell, MLC
    My HeatWare 77-0-0
