Ahoy NaMcO! It's really a pleasure to see your progression. Slick placement of the Aquaero I even like the HD mount - connectors toward the front for better wire hiding situation, I take it.
Do you plan on sleeving the fans tails?
[SIGPIC][/SIGPIC]
Now Playing
black freighter: i7 920 | evga classified | mm extended ascension pedestal | 2 x 300gb vraps
dead men tell no tales build: q9770 | asus striker 2 extreme | 2x4gb ddr3 ocz reaper | 2 x gtx 280 oc2 | 2x 300gb vraps | mm ufo-cyo | pcp&c 1200W
Thank you. Nope, the EK 250mm res weren't drilled in any way, they're like that originally
You might figure it out with the images below... Yep, there's lots of excellent projects around and some are *truly* inspiring.
Thanks mate!
The circles are a inner piece that will hold a future air filter. The filter will be between the outside mesh and that piece. This was a major flaw with the TJ07 and it's been solved this way
The LCD is an Alphacool 200x128 points (dual bay) model. USB too.
Hey there Cap'n!
The HD mount towards the front was indeed thought out in order to make cable routing easier, good eye there
If by fans tails you mean the coloured wires, yeah, those will be sleeved as well to be perfect black
Small preview of how it will look like once finished...
A few things will change after this "test mount", but not that many
This is what's happening right now, little work "behind the scenes":
This is a costumization of the fan extensions so there's not excessive wire length inside the case...
I did a new set of SATA sleeving...
Orientation of the PCI-E cables, the light blue shrink is being replaced by black:
Used flash here:
General view, side already covered by the acrylic panel:
Another angle, this is almost like the final mount, little to do in there:
Top fans being tested, i still have to sleeve the coloured wires:
And that's about it. During next week i hope to have the build finished
Thanks for looking!
ASUS Sabertooth P67B3· nVidia GTX580 1536MB PhysX · Intel Core i7 2600K 4.5GHz · Corsair TX850W · Creative X-Fi Titanium Fatal1ty
8GB GSKill Sniper PC3-16000 7-8-7 · OCZ Agility3 SSD 240GB + Intel 320 SSD 160GB + Samsung F3 2TB + WD 640AAKS 640GB · Corsair 650D · DELL U2711 27"
Amazing, simply Amazing build.
Components;
»Obsidian 800D
»CPU: Intel Core i7 940 OC'd to 3.69
»Motherboard: Evga X58
»EVGA GeForce GTX 295
»CORSAIR DOMINATOR 6GB (3x2GB)
Water cool parts;
»RAD - EK XT360, EK XT260 & XSPC RS120
»CPU Block - Alphacool H14 Yellowstone BRB
»Koolance Northbridge/Southbridge Water Block
»Black Feeser Mosfet Block
»EK-FC295 GTX GPU Water block
»EK-Multioption RES 250
»2 x Swiftech MCP355™ Water Pump
»XSPC Dual Acrylic Top
Really nice work mate, It's all comming together nicely.
I also think the black heat shrink will look better as well.
Is it just the photo or it your card bent a little?
Luuuuuuuuurve it!! And performance-schmerformance those fans FD are a million times sexier than GTyphoons.
love the look of this build. clean is an understatement here.
- Silverstone FT-01B
- Corsair HX620
- DFI LanParty DK 790FX-M2RS
- AMD X2 6400+ BE w/ Thermalright Ultima 90 @ 3.2
- 2 x 1 GB G.Skill DDR800(4-4-4-12)
- 2 x 1 GB Corsair XMS2 Dominator(4-4-4-12)
- BFG Tech 9800GTX(stock cooling for now)
- 2 - 250GB Seagate SATA
Very nice looking build. I really love it !
Keep on working on this very nice build.
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
Excellent namco. It's getting better and better, I appreciate your work. Anxious to see the final result.
- Project Completed -
I tought this day would never come, but finally managed to get some time in order to finish this build. There were only a few details left, but details take their time and a LOT of time too...
Okay, no more delays, here are the final project pictures. Let's begin with a few blurry night shots:
Front detail with power on:
Some exterior pics with the UV neon turned on, my camera doesn't like night shots at all:
And here are the final shots. Well, ALMOST final, i still had to sleeve/fix the neon starter:
Hope you enjoyed it, i SURELY did
Can't spend much more time here, i need to go off and enjoy it! Thanks a lot for watching, it's a pleasure to share this with XtremeSystems and i will surely return someday to this section of the forum!
See ya!
NaMcO
Great job NaMcO! Congrats!
Wow, awesome outcome!
It's got a very "clean" look over it as well, very nice!
Really nice mate
Very good look on your tj07 but the photo quality aint the best .. but the project is awesome !
Parabéns !
congrats on finishing, you did really great job
I really like tube routing and those neat cable guides. And can you show us overall picture of the back where cable management is? It seems to be very good
Worklog: Project Black Copper
Lian Li PC-P80 | Thermochill PA140.3 | Noiseblocker fans | mdpc-x stuff
Very nice! It turned out fantastic. I'm really interested to see some full shots of the back though, could you post any??
Very clean build, great job!
|::| i7 920 3849A914
|::|EVGA Classified 760
|::|G.Skill Trident 6GB DDR3-2000
|::|BFG GTX 275
|::|G.Skill Falcon 2 128GB
|::|WD BLACK 1TBx2
|::|Ultra X3 1000W
|::|Powered by Heatkiller LT/Ek-Classified/EK 275GTX /Feser x360/MCP355x2
|::|LCD: Samsung T260
"Sharing your knowledge is always the best way to learn new things". OPB
awesome build Namco.
- Corsair HX620
Congratulations NaMcO on an excellent build.
I have really enjoyed following this build, I am a tad sad to see it finish but very happy for you that it has turned out so well.
Thank you also for putting up with my constant questioning about this and that.
I really do appreciate the time and effort you have spent on answering all of them.
Thank you!
All the best mate, now have fun with it!
WoW and re-WoW!!!
my favourite so far!!!
doctor pepper's desk
EVGA P55 FTW | i5 650 @ 4GHz | 4Gb Corsair Dominator DDR3-1600 XMS3 | XFX 4870 1Gb | Corsair X32 | Samsung SpinPoint F1 - 320Go | Fractal Design Newton R2 650W | Samsung P2450H | Microsoft Laser Desktop 7000 | JBL Spyro Black
AirCooling: Prolimatech Mega Shadow | Xigmatek Bifrost | Fractal Design SATA Cluster Box | Fractal Design 2x120mm, 2x140mm and 1x92mm
Cosmos-S
Foxconn BloodRage Rev1.1 Bios P07 | i7 920 D0 @ 4,629GHz max & 4,3GHz stable | 6Gb Corsair Dominator DDR3-1600 | XFX 5870 | Sonar X-Fi | Intel X25-M 80 Go PostVille | Samsung SpinPoint F1 - 1To | Corsair HX620W | CoolerMaster Cosmos S | Samsung T240 | Logitech MX-5500 & Z-2300
Watercooling: Laing DDC + plexi top and tank | CPU - HK 1366 rev 3.0 LT | GPU - EK Water Blocks EK FC5870 V2 - Acétal Nickel | MB - Foxconn's original | HDD - HK SilentStar HD-Single rev 2.0 | radiator - 3x120mm | tubing - High Flex 10/16mm | red PrimoChill ICE coolant
Beautifull - love large honeycomb!
~Bex
PROJECT :: The Xtreme (WET) Dream!!!
PERSONAL H2O BESTS :
E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.6GHz i7 920 @ 4.6GHz
PERSONAL AIR BESTS :
Sempron140 @ 4Ghz (Stock Cooler) i7 3960x @ 5.4ghz (Air Cooler)
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
Nice, Nice, Nice - I love it.
Congratulations on an excellent build, Namco!
It came out looking really awesome.
I enjoyed your journey from beginning to end.
I noticed you didn't remount the ROG chip? I might just do the same and use mine as a doorstop, paperweight or boat anchor.
Enjoy your system!
Really nice outcome, one of my favourite TJ07 builds The only thing letting it down is the rear (pci blank section) a little more prep time would of finished it off nicely.
I7 920 D0 (4.2GHZ HT on) // eVGA Classified // 6GB Corsair dominator 1600mhz // Asus HD5770 x2 // Corsair HX850 /--/
PA120.3 // EK Supreme LT // MCP655 // MM Ufo (soon to be TJ07)
Namco - beautiful work and love all the custom pieces...
