Results 1 to 15 of 15
Thread: 5.25 Bay 120mm fan housing?
    Mar 2008
    Are there any other good bay devices that can simply be used for airflow?
    So far all I can find is the Silverstone CFP51 and CFP52B, but both of those are for hard drive cages so they unnecessarily obstruct airflow with the excess construction.
    All I want is a way to mount a 120mm fan intake in three bay slots.
    The main reason I ask is that a nice sleek one would be a great addition to the Corsair 800D to add airflow into the motherboard area and/or a top mounted rad. The single 120mm intake from the bottom seems like it would just cripple any serious cooling in that case.
    Bill Cosby: Stewie, what do you think candy is made out of?
    Stewie Griffin: Sunshine and farts! What the hell kind of question is that?!
    Oct 2006
    Shanhai China
    something like this
    Cooler master and others do something like this, 4 into 3 Modual. I have the CM 690 case and just fitted a 120mm fan behind the DVD 5.25 slots that I was not using, its metal mesh and foam construction.
    http://www.newegg.com/Product/Produc...=STB-3T4-E3-GP
    24/7 PC CoolerMaster CM690 + 7 fans(its HOT as HELL in Shanghai) Intel Xeon E3 1230 3.3-3.7Ghz, 2x8GB DDR3 1600 G-Skill, HD GT630 2GB, Scandisk Pro 256SSD 2x2TB Green, 2x 3TB WD Green Data Drives. HTPC Q8400, EP45 UD3L 4x1GB Gskill6400, 1xWD Black 640GB,2x2TB WD Green, 2xWD 1TB Blue(RAID1), Sapphire 4530 512MB,
    Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.
    Mitch Ratcliffe, U.S. technology journalist and blogger
    Mar 2008
    Yea they all seem to be hard drive cage adapters though.
    Doesn't seem to be one completely dedicated to simply a fan mount.
    Aug 2008
    Rockville, MD
    You could probably just use some zipties or tape/velcro
    Main PC
    i7 3770k
    Asus P8Z77-Deluxe
    4x4 GB Gskill Sniper
    Sandisk Extreme 240 GB
    Gigabyte GTX 670
    Coolermaster ATCS 840
    MCP35X - Apogee Drive II - MCR320
    HTPC
    i7 920
    Gigabyte EX58 UD5
    Sapphire 5670
    3x2 GB OCZ Platinum @ 7-7-7-20
    Corsair HX-650
    Silverstone LC10
    Intel X25-M G2
    Mar 2008
    Quote Originally Posted by cobra_kai View Post
    Not a particularly elegant solution.
    Looks like I'd have to custom fab it. No biggie, was just hoping there was already an elegant solution out there.
    Oct 2008
    Warsaw, Poland
    There is solution http://www.undesignsbrackets.com/ made for radiators but fans also can be mounted
    Build in progress :
    Case - CM Cosmos S
    Mobo - EVGA X58 Classified E759 w/c EK full block
    CPU - i7 975 w/c with Watercool HK Rev. 3
    RAM - Corsair Dominator GT DDR3 3x 2GB 2000MHz CL8 Core i7
    GPU - EVGA GTX285 Tri-SLI, w/c with EK blocks
    PSU - Corsair 1000HXEU
    parts completing
    Turn of my robotic brain. All my thoughts are all the same.. all insane..
    Jan 2009
    ASUS Maximus VI Impact | Intel Core i7 4770k | Sapphire HD 5870 | 2x8GB Corsair Vengeance 1866 | Corsair 760AX
    Aug 2007
    Kent, Washington
    If you can't find any more Kama Bays it's because they release the Kama Bay II. I think all they did is replace the fan.
    Dec 2008
    Sweden, Linköping
    http://www.aquatuning.de/product_inf...Fan-Frame.html
    Should fit in any case, some minor modding worst case scenario... Gonna get one and try myself in my CM690
    SweClockers.com
    CPU: Phenom II X4 955BE
    Clock: 4200MHz 1.4375v
    Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
    Motherboard: ASUS Crosshair IV Formula
    GPU: HD 5770
    Mar 2008
    Awesome. Gonna try to find a reseller here. That looks like it'd go very well with the 800D.
    Doesn't have to be incredibly powerful, just enough to blow some fresh air into the case since I'm still a little wary of that lone 120 or 140mm intake at the bottom.
    Quote Originally Posted by Smartidiot89 View Post
    Son of a ..... How did you find that? lol I SCOURED that site trying to find something like that. Dunno how I missed it.
    Dec 2008
    Sweden, Linköping
    Quote Originally Posted by kgk View Post
    LMAO you're welcome I always keep track on some "odd" companies like Sharkoon and Nexus always pays of for some "necessary" equipment like that
    SweClockers.com
    GPU: HD 5770
    Jan 2007
    Braga, Portugal
    Well, my recently-acquired Nox Coolbay Basic tower case comes with one of those.
    It's a VERY simple fan holder that extends 90º to the nearest screw holes.
    It's a MAJOR pain to find some images of it, but I think I managed to do it.
    Check [URL=http://www.hard-h2o.com/reviewimg/cajas/nox-coolbay/12] and [URL=http://www.hard-h2o.com/images/reviews/cajas/nox-coolbay/10tb.jpg[/URL].
    You can try to get Nox to send some of those your way, though it might be easy to build, it seems fairly simple...
    Cheers.
    Miguel
    Don't forget to visit http://www.xtremesystems.org/forums/...play.php?f=214. Stop wasting CPU cycles and FOLD. Put your extra CPU power for a good use.
    Xtreme Mentor
    May 2008
    cleveland ohio
    Quote Originally Posted by cabbspapp View Post
    slip stream thin 12mm x 120mm 1200 rpm model.www.frozencpu.com
    has them now.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
    Apr 2005
    All systems sold. Will be back after Sandy Bridge!
    Xtreme Design
    Aug 2009
    Central Texas
    I've seen these for a while now on their sites, but actually finding a place to purchase them from can be a challenge. A pity too.
    Not From Concentrate
    All Projects
    Previous Projects:
    S3 Mini ITX Chassis
    The ArK
    Uriel
    Israfel
    Veritas
    Eldritch
