They are also on Guru3d and TechPowerUP for Vista/7 64 & 32 bit.
Intel i7 920 C0 @ 3.67GHz
ASUS 6T Deluxe
Powercolor 7970 @ 1050/1475
12GB GSkill Ripjaws
Antec 850W TruePower Quattro
50" Full HD PDP
Red Cosmos 1000
Can't see any 9.7
Intel i7 2600k, Asus p8p67 EVO, Thermalright Archon, G.Skill RipjawsX 8GB, Asus EAH6970 DCII, Corsair AX850W, Asus xonar essence ST, Coolermaster HAF 932,
Crucial C300 128GB, WD Caviar Black 1 TB, Samsung F3 1TB.
The world needs your support.
Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
Lol, CatalystMaker on Twitter tells us they're released and on game.amd.com, and TPU and G3D have mirrors, but nothing on the official AMD site
Rig specs
CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
Foundational Falsehoods of Creationism
I just installed them but will go straight back to 9.6.
I always used to be able to throttle the fan down using the manual fan control, but now I can only raise the fan speed? What the hell....
Just installed. Initial reaction? Not happy - refresh rate stuck at 59Hz, GPU scaling greyed out, new layout is trying to be simplistic but is harder and more time-consuming to navigate.
I'll keep them installed for a few days to see if gaming performance makes up for it.
Strange, manual fan control works exactly as in 9.6 for me. Can change speed just fine
Rig specs
Core i7-4930K LGA 2011 Six-Core - Cooler Master Seidon 120XL ? Push-Pull Liquid Water
ASUS Rampage IV Black Edition LGA2011 - G.SKILL Trident X Series 32GB (4 x 8GB) DDR3 1866
Sapphire R9 290X 4GB TRI-X OC in CrossFire - ATI TV Wonder 650 PCIe
Intel X25-M 160GB G2 SSD - WD Black 2TB 7200 RPM 64MB Cache SATA 6
Corsair HX1000W PSU - Pioner Blu-ray Burner 6X BD-R
Westinghouse LVM-37w3, 37inch 1080p - Windows 7 64-bit Pro
Sennheiser RS 180 - Cooler Master Cosmos S Case
Hope I'm not going too far OT here but the slider for the fan speed used to go from 0% to 100%. It's probably because its not a reference card, but even though its anoying to have feature that I liked and used taken away.
WTF, it didnt need a gui change =/. once you have a good thing... leave it. or at least give an option to switch to the old look.. like Vista. lol
[MOB] AM3 Asus M4A79T Deluxe
[GPU] ATI HD 5870 1gb 925 mhz
[RAM] OCZ Reaper 4gb 1600 mhz
[CPU] AMD Phenom II 965 4.0 ghz
"What doesn't kill you, only postpones the inevitable..."
Water Cooled Apevia X-Plorer | Custom Window | Lapped Phenom II 955 | Lapped Phenom 9850
Rig specs
I'm not really sure why they're changing the gui again, instead of spending time on useful things like per application profiles. ATI cards are nice, but the software sure does suck ass.
core i7 920, gigabyte EX58-UD5, 4870x2
DDC3.2 > PA120.3 > DD4870x2fc > Fuzion v1 > PA120.2 > EK Res
So, if everyone hates the new GUI so bad, why change to it? Just install the new display drivers and keep the "old" CCC....it does work, btw. Just upgraded the drivers to 9.7 and left the "old" GUI in place and it works just like it did before with 9.6, no complications, no problems.
Hrmpf, the new 9.7 driver doesn't even let me set the clockspeed neither up nor down. I rolled back to 9.6 now.
I got the Gainward HD4850 Golden Sample btw, somehow the new driver seems rather incompatible with that non-reference design...
I'm not touching the new CCC with a 10' pole for at least 3 months, probably 6. I really don't understand why they're ing around with the GUI when they can very easily apply the same man hours to fixing incompatibilities with games or by adding features that people actually want.
Wouldn't the new driver work with older CCC?
I don't know why every time when CCC has newer version the lower benchmark score I will get (with same setting)... Does anyone has the same issue? Or I am doing something wrong.
Q9450 w/120 extreme
Maximus II Formula
G.Skill 4gb 8800 w/ crosair fans
Sapphire HD4870 512 w/ T-Rad2
2x 300gb velociraptor RAID0
2x 500 gb SATA
Cooler Master 850w PSU
CM 590 Case
LOL 50% fan speed. I think my ears would die. Then again I do have a reference card so I should be good to go.
Will dl and install this tonight.
mine starts at 20% on the fan speed slider
and i got these from AMD's site yesterday. No probs in L4D and UT 2k4
Mpower Max | 4770k | H100 | 16gb Sammy 30nm 1866 | GTX780 SC | Xonar Essence Stx | BIC DV62si | ATH AD700 | 550d | AX850 | VG24QE | 840pro 256gb | 640black | 2tb | CherryReds | m60 | Func1030 |
HEAT
I've had problems getting them to work with two monitors, I can't make my TV primary so I have to disable the monitor and with the TV enabled I can't set the monitor to 1600x1200 (best resolution for it) so to switch between I have to disable or unplug which is less than perfect. I blame DRM and the HDMI spec not ATi though.
It also messed up my OC, Riva tuner kept the OC on one GPU but not the other causing games to crash (L4D after 5 minutes) until I figured it out.
Overscan on HDMI is still a problem in Crysis and RE5 Bench (Full Screen DX10 apps over HDMI at 1920x1080 set the screen at -15% despite having the slider at 0%, DX9 apps work fine), the default should be 0% instead of -15% to get around this.
ASUS 6T Deluxe
12GB GSkill Ripjaws
50" Full HD PDP
Red Cosmos 1000
