Its a long story, but im just wondering if anyone knows how to repair trace damage on a motherboard, or if it can even be done.
Dell XPS rig - RIP 2004
Custom Intel Core Duo rig - RIP 2007
Alienware Aurora 7500 rig - RIP 2011, de-comissioned and being scrapped
Dell Latitude ATG D620 - Sold 2012!
MSI GE-60 0ND with Crucial M4 128GB SSD
I have never tried to repair a mobo but I have used silver conductive paint to repair other circuits.
A small bottle can usually be picked up for say £6-10, although I should imagine mobo traces would require one heck of a steady hand.
Hiper HPU-4M880, Q6600@3.6Ghz 1.5V, Abit IP35-E, 2x2GB OCZ Dominator PC8500, [COLOR="Blue"]XFX 6950Watercooled
Yeah I can only imagine lol. The board is an Asus P5N32-SLI Deluxe btw if anyone has any experience.
Uhm, you did realize, that the traces are not the only problem that you are facing, right?
Chip on left is broken..
i7 930 D0 - 4,2 GHz + Megashadow
3x4GB Crucial 1600MHz CL8
Foxconn Bloodrage rev. 1.1 - P09
MSI HAWK N760
Crucial M500 240GB SSD
SeaGate ES.2 1TB + 1TB External SeaGate
Corsair HX 850W (its GOLD man!)
ASUS STX + Sennheiser HD 555 (tape mod)
Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
Yes I realize that also. Is that also repairable?
That looks like a washer/nut was torked onto there super tight. You'll have to scrape the lacquer and letter paint off to expose the trace wires because slapping conductive pen on them as is, will accomplish nothing.
then you have the broken chip, APM2014N which is an N-channel enhancement mode MOSFET and without it, your board is useless or it will eat your ram.
GB 790XTA UD4
GSkill Pi Black 2000 Cas9
ASUS 4870
Enermax Revolution 1050+
http://www.heatware.com/eval.php?id=67661
The resistor under the IDE/Floppy(?) slot doesn't look good, too, and I don't know if the solder pads right above the mosfet really used to be empty.
And BTW, forget conductive silver lacquer. It's not really permanent and those traces are far too thin to get a decent replacement by using the lacquer. First you should check if the traces are really cut. If they are only scratched, carefully retinning them might suffice.
Does anyone think its worth repairing to sell or should I just sell it to an expert for them to fix.
it's a P5N32-SLI dude, i don't know how you could justify spending money to get an old mobo repaired...but that's just me
I'd give it to the first guy to offer anything for it, even if it was only five bucks.
If you have to write it off, life goes on.
As mk-ultra said, it's an old board. Not worth the trouble!
i5 750@3800
Noctua NH-U12P/120x38mm Panaflow M1
GSkill 4G DDR3-2000 Ripjaws
EVGA P55 FTW 200
EVGA GTX 480/Zalman VF3000F &
Zotac GTX 480 AMP Edition/Zalman OEM VF3000F SLI@800/2000
Seasonic M12D 750
WD Caviar 500
Coolermaster HAF 932 Black Edition
W7 64 Pro
fix it just for yourself. give it a new name and sell it for twice its worth now.
CPU: C2D e6300 @ 3360MHz 1.33125v bios 24/7
RAM: 2x1GB OCz reaper pc2-9200 1203MHz 5-5-5-18 (Intel 1200MHz) 2.000v
MoBo: DFI LanParty UT P35-T2r 12/24 BIOS
Storage: 1xSeagate 80GB sataII, 2xSeagate 500GB sataII = RAID1
VGa: eVGa GeForce 8600gts ssc edition 756/2140
PSU: Corsair 850tx ((+12V@70A))
Cooling: Tuniq Tower
Case: Antec SoHo Server (Black)
i did some track repairs to a dfi lan-p a while back its still untested but the tracks are fix'd and connected (mm tested)
this track has gone
fix'd image here
http://i90.photobucket.com/albums/k2...p/DSC02811.jpg
i had to wet and dry the lacquer from the mobo then tin with solder and use a single strand from a 16core wire and just rejoined the tracks
carl..
I LOVE LAMP!
If you can get the mosfet (get an old, broken board and use that as a donor), that problem is easily and cheaply rectified - as long as traces on the intermediate layers aren't damaged........
Never argue with Idiots...they will drag you down to their level and beat you with experience!
i-Prodigy (small APD2 GFX/CPU waterloop) ; HP Blackbird Project Log (dual-Xeon Watercooled) ; Macho Mini Project Log (Sandybridge watercooled mini-ITX)
This thread reminds me how the distributor fixed my old epox MB.
I had a 9700NT which chose to self-destruct and killed/burned the AGP slot.
The HK distributor used thin stripe of metal and soldering to fix it.
