Ok, I just received my TFC 480 from a-c-shop.de
They have a great service, and easy contact. I was shipped in just 3 days.
I'm a bit disappointed by some points with the TFC radiator than none pointed out:
1- The build quality is questionable compared to thermochill. Even if the finishing is much more clean than the thermochill, the overall steadiness of the TFC is far behind the thermochill. The radiator housing is easily bending when handled firmly while it is more robust on a thermochill. The overall radiator casing seems also much thinner
2- Still not persuaded? The TFC 480 weight is 1780g (I verified it) despite what they say on the web site (2500g they state is the total packaging by post they send you ) The PA120.3 on the other side is 1800g!!!. Guess what! A triple radiator heavier than the quad from TFC, and both are stated to be copper
Watson, there's a problem here I guess. Either they add aluminium despite their claims or the radiator is much much more thinner overall, or both at the same time
If only someone could verify they really use copper, I'm now really begining to doubt it (paranoia mode ON)
3- There's still some spacing between the fans. Yet, the TFC doesn't come with any neoprene gasket to completely seal the fans to the radiator. Just some 120mm silicone antivibration pads. I guess, a neoprene gasket with very low RMP fans will improve performance like on the thermochill. So, you'll have to make your own gasket
In anycase, now, based on their weight, these radiators are extremely overpriced and I'll recommand going for a PA120.3 instead of their quad crap
It could perform the best, but it is really light on quality at my opinion
Strange I'm the only one noticing this. Especially Martin's that handled both the PA120.3 and the TFC 480
