Hi Guys
Thx to Saaya, i had a chance to play with Cellshocks new 1866 8-8-8-16 Blue sticks. i will only show some fast 1m results for now, and later test 3d with more tight sub timings, and also see how they scale with more vdimm.
All tests is done at 2.08 vdimm for now. Also i will try to see how high i can go with higher TRAS later.
Cas 6 results will come later
But here are a couple of initial 1m results, to give you a idea of what the mem are capable of![]()
Setup:
P5E64 WS Evolution
Cellshock DDR3 1866 8-8-8-16
E8500
NQ giant Reactor 1kw
The Memory:
Part number : CS3222770
Capacity: 2GB-Kit (2x 1GB)
Configuration: 128Mx64 DRAM Micron Device
Config: 128Mx8 PCB 240pin
Module Info: unbuff. non-ECC, DDR3 DIMM
Speed: PC15000
CAS Latency: 8-8-8-16
VDIMM: 1,7V-2,0V
Warranty: 5years
Cas 7-7-7-14 1T 2.08v 1021mhz
cas 8-8-8-14 1T 2.08v 1060mhz
Stay tuned for more results![]()
