Firstly, I would like to thank all of you for making XS what it is. There is an absolute wealth of knowledge and information within these forums. Secondly, I need some help with creating an awesome watercooling loop.
I have these Parts in mind for the loop;
1 x MCR 320 rad
1 x MCR 220 rad
1 x Apogee GT
1 x MCW60 GPU block
2 x MCW30 waterblock
1 x swiftech hi-flow res
1 x D5 variable rpm pump
If you see anything wrong with the parts listed above please let me know. Now onto my questions :
1. I want to have compression fittings on all the parts. What size tubing will be suitable for these sorts fittings? and is smaller tubing detrimental to the loops cooling effectiveness?
2. Is 1 D5 pump enough to sustain a good flow-rate?
3. How do I set up the loop so I can simply fill the loop externally and drain externally without taking the parts out of the system? Please suggest ways I can do this.
Thank in advance guys.
