Update your everest, your version is rather old, 4.60.1500 is the latest non beta....Maximus has problems with older Everest
Depending on bios version ect you might need to update your chipset drivers
Nice idea Grnfinger, in general (esp. for "sys.builder-newbies").
Assuming false sensor readings means checking/comparing different software and BIOS values, doesn't it?
Even tried the Extreme sensor for OPT`s (<=> Zalman f.e.), different CPU-fans, various case fans and , RAM-kits, settings etc.
I'm a bit used to thermodynamical problems, due to automotive engineering decades ago.
But thy old man is obviously unable to conclude.
RMA, by the way will take up to six weeks in Germany.
NH-U12F(NF-P12)/QX6850/Maximus Formula/2x Cellshock CS2221550
HD5870 VaporX/SB X-Fi Fatal1ty/WD1500HLFS stripe/WD6401AALS/iHAS424
Enermax Modu 87+ 600W/Lian Li A16A/aquaero 4.0 VF
these are nice boards ive had 3 of them they all sold for more than I bought them for, and oc'ed insanely we'll
i5 3570k 4.2ghz 1.28v H100 cooled stable 24/7 | Asus Sabertooth Z77 TUF | 2x4GB 8GB Mushkin Blackline 998954 | GTX 680 2gb | 120GB OCZ Vertex 3/3TB Seagate | Enermax Platimax 850w | NZXT Switch 810 White | Windows 7 Ultimate | Samsung 40" LCD HDTV
A+ NET+ Linux+ MCP MCTS MCSA MCITP
World of Tanks WGLNA
CSGO ESEA
Heatware: MarcusFoX
Core2 Q6600 - Go
ASUS Forumla Maximus SE (1207)
GSkill 4G PC2-8500
Silvertone 750W
Freezer 7 Pro - Artic Silver 5
Antec 900
Samsung SH-S203B
Seagate 250G x2 AHCI
EVGA GTX260
OK, So it's been awhile. Can I get some feedback on some of the to date known best 2x2gb kits of OCZ or other quality ram kits to do best in the area of 1150 on this mobo?
I have moved to DDR3 on my P6T6-WS but want to run this old mobo on Vista ult x64 and want soem good DDR2 to OC to DDR1153. Any good suggestions?
Here's what I looked at so far; OCZ Platinum and the 4gb kit of my current (great RAM to date BTW) the Crucial Ballastics Tracers. Only not sure how the 2x2g kits holds up to the great rep of the previous 2x1g kit I run now. I also had great luck w/ OCZ Platinums in an older 2x2g kit of PC26400 OC'd to DDR1000 on an old P5WDG2-WS and still running solid at 2.2v. My current DDR3 in a Rampage II extreme I'm testing seams nice so far but I believe they are still too expensive for the old DDR2 version to bother w/ for a 2nd gaming PC. What do you guys think.
thankx in advance.
EDIT: Oh ja, just to know, yes, I love this mobo and i has served me well and a solid OC'r for over 15months nnow w/ only one hick up to date. well reccomendsed to any one interested
4.250GHz (1.331v) @ 212 x 21 @ 2:8 DDR1600 @ 6-7-6-18 (1.657) ASUS RAMPAGE EXTRENE w/ Q6600 @ 3.8Ghz daily
ASUS RAMPAGE II EXTREME, X58 w/ ICH10R
Intel Core i7 930, rev. DO, batch #3951A824
Mushkin Redline 998691 PC3-12800
ASUS ENGTX460 GTX-460 DirectCu 1G
Creative X-Fi Titanium Fatal!ty Champion
SilverStone Strider ST80F 800W Quad 12v
WD Raptor 74GB, 10K x4
Danger Dan WaterBox Plus
Windows 7 Enterprise x64
Swiftech Apogee XT Copper Top w/ AS#5 (lapped to CPU)
Hi everyone,
I use Rampage Bios 0403 for my Maximus foruma. this bios doesn't fully support E8500, it doesn't have option for me to set mulitplier and CPUz detected the multiplier = 9 instead of 9.5
Is there any new Rampage BIOS fully support 45nm processor?
sorry to bump this board but I am having an issue on Vista x32 with my AHCI controller Device\Ide\iaStor0, did not respond within the timeout period
I have tried everything I I just cannot solve this issue at all. For the life of me every fix does NOTHING!!!
What I do not understand is the chipset on this machine is Intel ICH9 and I swear that the SATA controller (I am using AHCI mode) is Intel and should use the Intel driver and the JMicron is the IDE only. On ASUS's site there is nothing that mentions Intel as the SATA controller and only JMicron. Is this true? and have I been using the wrong driver for over a year now and getting away with it?
thanks for anyones help. Also if you seen this issue and resolved it how did you do it? I have updated to the latest Intel SATA\AHCI driver and disabled LPM mode for each drive in the registry from recommended fixes. This did not work for me....
thanks
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
For starters, it is overclocked beyong 10% or more? If you have a medium to high OC, you will need to increase the SB voltages as well as the NB a tad help stable it out. Remember, lots of devices run through the SB, especially that Intel ICH9R hub.
AHCI on Intel is the same thing as single disc RAID in RAID ready more as long as you choose the correct driver at 3rd party install in OS set up. If you do choose AHCI you cannot change to RAID or RAID ready and into RAID later. If you start w/ RAID ready, it installs as AHCI/RAID Ready untill you choose to migrate a RAID or just leave it as so.
The latest and correct for this mobo is v8.7.0.1007 @ 1/9/2009 for the Intel ICH9R Intel 4 & 3 Series drivers
thanks for the reply. I am only OCing very light. 2.4 is stock and I am at 2.6
It's kind of weird how I installed AHCI. I was using standard IDE setup for SATA in XP and decided I would switch to ACHI mode and load the driver just before I switched over. I had never tried it this way so I was taking a chance on it not booting. Well it booted fine and I've been using this mode ever since. The only change besides upgrading drivers when they are available is upgrading from XP Pro to Vista Ultimate x32. So I never recieved that error before in XP and never had an issues buring a CD or DVD (this is how I found the issue) Thing is it has been happening since I moved to Vista and I was not aware of it. I should of looked in the logs when the drive would freeze for 2 to 5 seconds. I am using a Seagate 7200.10 drive and not .11 that some suggested. Since reloading drivers from last known config I have not tested creating a CD or DVD and have not seen that delay, but it is still too early to tell.
seems like the only thing really different here is Vista
thanks
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
still getting this event and really I do not get it at all. Vista is the only big change to my system The device, \Device\Ide\iaStor0, did not respond within the timeout period.
So using my burner on this machine out of the question and pretty much useless at this point until I upgrade to a Core i7 or whatever is out when I buy. I am surprised others using
Vista, this board and a Seagate drive (if that is part of the issue) did not see this and why am I the only one here that has seen this.
thanks
Core2 Q6600 - Go
GSkill 4G PC2-8500
Silvertone 750W
Antec 900
Samsung SH-S203B
EVGA GTX260
OMG!
This Thread is crazy go nutz! Thank you to all who've contributed, whether you are here reading or not!!!
This is truly PACKED with serious info!
If this thread is dead, totally, i apologize
I've run across a Maximus Formula that i've dropped a good old E8200 into that just happens to be groping 8gb's of 1066mhz rpr. I've OCCT'd it at 3.9ghz and am looking to push past that yummy 4ghz mark! Been there already but can't get stable. I know this is waaaay old school for you OC guru's but, some of us don't mind the 'hand-me-downs' and like fiddlin' with the 'last' generation, or older, of tech!
Sooo, that being said, i'm about 30mins into an OCCT run at 3.9ghz. the only tweeks on this setup/mobo is cpuV and a tad of pciE. 1.35V&111pciE respectively.
Any Pearls of wisdom from the old schol, would be much appreciated
And, actually, this is just some benching. This is actually gonna be a mobo upgrade for my father. The E8200 is gonna be lost to an old fashioned
Q6600.
I'm tryin' to kick him towards the I7 bandwagon, but to no avail. You work with what 'cha got, ya know?
Anyway, thanks in advance for any response(s)!
M$
ps-google is a wonderful and crazy thing, huh?
pss-Shout out to the Commander!
g
post up your bios setting and suggestions can be made, I have a few templates for 8400, 6600, 6700, 9550 and 9650 chips
Flashing the bios to Rampage would be a good idea, it got me higher clocks and better bandwidth, something to consider if your benching
Is there a "guide" that explains settings and gives recommendations for ocing 9550's on this board? I mean, I know there's bits and pieces scattered throughout this MASSIVE thread, but is there a single reply, doc on another site...anything? And Cleatus, I wouldn't mind that 9550 template. Thanks guys.
there should be a few but I cant remember what and where... biggest contributors were Kup,Zuker2K and Grnfinger iirc, search there posts and you should do ok
I'll hunt up my templates and post them this afternoon when I get home from work...
Sorry for the delay cleatus, but i've been swamped at work as well as learning this asus board and bios! anyway, not sure how the template works but here's what's OCCT'd Stable at 3.9ghz, but i'll be damned if i can squeeze that sucker to 4.0ghz! i even thought about a hole right at 500fsb and tried 501&502,,,,no luck! anyway, again, this is just fartin' around, my dad's box comes over this weekend and i'm gonna drop his Q6600 in it and set up his raid 0 array as well. Also, i just got in the mail today the original Accessory box, brand new off of ebay to go with the bare board from my buddy! sweet bells and whistle's, just wish it was the SE, LMAO!!!!!
tx again for any sugg's in regards to the e8200 as well as the Q6600 comin' this weekend!
M$
ps-are any of these 'asus' programs that come on the original disc worth a crap?
i.e.,,,,ai booster, cpu level up, Qfan2, ai nap, ai gear3, ai suite, pc probe? if they are anything like the stuff MSI puts out with their mobo's forget it!
just curious as i haven't loaded squat on anything yet, also how about the bios flasher from asus? if not, why? & what then?
tx
BIOS: 1201
Extreme Tweaker
Ai Overclock Tuner : manual
OC From CPU Level Up : I DON’T HAVE THIS???
CPU Ratio Control : manual
- Ratio CMOS Setting : 8 (7or8 are my only choices)
FSB Frequency : 488
FSB Strap to North Bridge : 400
PCI-E Frequency: 111
DRAM Frequency: DDR2- set itself to 950(mem is reaper 1066mhz)
DRAM Command Rate : 2T
DRAM Timing Control: auto
CAS# Latency :
RAS# to CAS# Delay :
RAS# Precharge :
RAS# ActivateTime :
RAS# to RAS# Delay :
Row Refresh Cycle Time :
Write Recovery Time :
Read to Precharge Time :
Read to Write Delay (S/D) :
Write to Read Delay (S) :
Write to Read Delay (D) :
Read to Read Delay (S) :
Read to Read Delay (D) :
Write to Write Delay (S) :
Write to Write Delay (D) :
DRAM Static Read Control: enabled
Ai Clock Twister : strong
Transaction Booster : disabled
Relax: 0
CPU Voltage : 1.57
CPU PLL Voltage : 1.6
North Bridge Voltage : 1.55
DRAM Voltage : 2.10
FSB Termination Voltage : 1.52
South Bridge Voltage : 1.1
Loadline Calibration : enabled
CPU GTL Reference : auto
North Bridge GTL Reference : auto
DDR2 Channel A REF Voltage : ddr2_ref
DDR2 Channel B REF Voltage : ddr2_ref
DDR2 Controller REF Voltage : ddr2_ref
SB 1.5V Voltage : 1.5
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
Advanced CPU Configuration
C1E Suppport : disabled
CPU TM Function : disabled
Vanderpool Technology : disabled
Execute Disable Bit : enabled
Max CPUID Value Limit : disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support: Disabled
Hi there
I ve got this problem for some time, in some games, such as cod modern warfare 2, or cod4, everything works fine when suddenly, the frame frezess and I get an audio hang up, sort of stutter of the same audio piece of sondtrack, maybe someone had the sam problem? need the reset the rig to boot after that, I tried going up with the north bridge, and cpu voltage with no sukcess
any ideas?
p.s. while playing I don't overclock the card, maybe I need to cool down the north bridge, I ve got a spot fan on it blowing some air though???
BIOS: 1302 Maximus Formula
Extreme Tweaker
- Ratio CMOS Setting : 8,5
FSB Frequency : 430
PCI-E Frequency: 100
DRAM Frequency: DDR2- 861Mhz
DRAM Command Rate : auto
CAS# Latency :
RAS# Precharge :
RAS# ActivateTime :
Relax: 0
CPU Voltage : 1.325
CPU PLL Voltage : 1.5
North Bridge Voltage : 1.51
DRAM Voltage : 2.02
FSB Termination Voltage : 1.42
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
Voltiminder LED : enabled
CPU Spread Spectrum : auto
PCIE Spread Spectrum : auto
Execute Disable Bit : disabled
USB Configuration
Legacy USB Support: auto
thx for any suggestions
OS: Windows XP Pro PL SP3 / WIndows Vista x64 ULTIMATE pl / Mac Os X 10.5.5 - Ideneb v1.3 x86 project
Processor: Intel Core2 Quad Q9550 'C1' - VID 1200v @ 3.68ghz on 1.304v 433x8,5 (air noctua NH-U12F)
Mobo: ASUS Maximus Formula BIOS Rev. 1302
Memory: 4GB Geil Black Dragon DDR2 800 (1.8v) @ DDR2 866 5-5-5-18 on 2.0.1v
Monitor: Lg 227wt 22" lcd
Video Card: Gigabyte Geforce GTX260 OC 896mb @ 690/1240
Storage: 2x 250GB seagate 10 - RAID 0 + 500GB 32mb seagate 11 + 320GB seagate 11
PSU: Enermax Infiniti 650W
Case: Antec P182
3dmark Vantage: 11940 and will be more a bit
Looks like you and I have similarly crappy Q9550's.
FWIW, I can't get over 3.6 stable either. And I've tried high vtt/nb/vcore volts like you. Although, I'm starting to wonder if it's the Board/BIOS rather than the chip.
Case: Antec P182
Case: Antec P182
