I want to collect a load of temp data to investigate the issue of the E4300 temperatures. (Personally, I still think the newest CoreTemp reads them 15C too high. A friend's E6420 at similar settings loads around 15C cooler.)
If you could please set your CPU at 3.2GHz with 1.4375vcore (what mine runs at 24/7) and list idle and load temps, CPU, and what heatsink you are using. Load using Orthos, Small FFT's. Leave it running until temps stablise. I am using CT 0.95.
I will then look at the data, and it should give a reasonable enough indication if CoreTemp is lying. I am aware of the fact that it is not just E4XXX CPUs that have the 100C Tjunction, so it is less likely to be an error that it once seemed, however, they still seem too high.
Me first:
E4300: Idle = 45C, Load = 71C, HS = Tuniq Tower. CPU is lapped.
