[SIGPIC][/SIGPIC]
proof (take it however wished) vista just wasnt done when launched
E=mc2
vista=crap*c2
Nothing new to virtually everyone. Vista should be canceled as the first SimCity 3000 was, and rebuilt from ground up leaving only new driver model.
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
3570K ● Asus V Gene ● 8GB Mushkin DDR3-2133 ● EVGA 660 Ti SC ● Seasonic X750 ● 128GB Samsung 830 SSD & External 1TB RAID1
SupremeFX SPDIF -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> AKG K701
I for one did not have Vista crash on me yet and I have it on 4 machines including my lappy. The performance completely blows goats though.
poncho is right
XP had a lot of problems when it came out
this is the only thing that pisses me off about MS.....who are we betatesters and why do we pay for a product that doesn't work properly
i hope all these databases of issues will be put to good use on next OS to minimise issues to insignificance
Yeah couldn't agree more. Really love vista but it does blow on slower systems.
In regards to bugs I'm sure that MS did a lot of bug testing hence the two beta's and the release candidate but in a system as huge as an operating system it just is not feasable to release a perfect system the first time.
There are to many hardware configurations, software mixes and actions in order to test everything. I personally believe that MS did a really good job with Vista in reducing bugs. XP was substantially worse when it was first released.
Rig 1: Core 2 Quad q6600 under TR Ultra 120 ex, ASUS P5E Deluxe, 4x1Gb Crucial Balistix DDR2 667, 4870, 1TB samsung F1, Stacker 810, HX620
Rig 2: E6700 under Big Typhoon, P5b Deluxe Wifi, 2x2gb Gskill Pq, MSI 4850, Seagate 250gb 7200.10, NZXT Apollo, vx450
Rig 3: AMD64 3000+ under Ultra90, DFI NF3 UT 250g, 2x1Gb DDR 400, 7300gt DDR3, 160gb Hitachi Deskstar
Rig 4: m1730 core2 p9500, 2x8800gtx, 4gb DDR2, 2x250gb, Blu Ray
Rig 5: ASUS n10jc Atom @ 2.0ghz, 9300gs, 2gb DDR2, 160gb
I have used Vista for 3months until now,it's a good OS it could be better and I mean by that the fact that there are not much real differences between Vista and XP,the only thing I am not happy with is the 3rd party support for this OS....
Dont listen to these people that talk crap about Vista being the worst OS ever. They have no idea what their talking about. They are just listening to rumors and isolated incidents from people throwing fits because their expectations were super high, and they got less than what they had hoped for. They have no idea that Vista is actually the most stable and compatible OS to date on release as MS goes. Its so funny when i ask people' "Ok, what exactly are you having troubles with in Vista then." The answer is usually, "oh, I cant find drivers for so and so" Well, buddy, thats not really Vistas fault. Plus don't expect an OS upon release to have 100% compatibility with everything.
Whatever, Vista is not too shabby right now, and it will of coarse get better as time rolls along as the other OS'es slowly did.
This post above was delayed 90 times by Nvidia. Cause that's their thing, thats what they do.
This Announcement of the delayed post above has been brought to you by Nvidia Inc.
RIGGY
case:Antec 1200
MB: XFX Nforce 750I SLI 72D9
CPU:E8400 (1651/4x9) 3712.48
MEM:4gb Gskill DDR21000 (5-5-5-15)
GPU: NVIDIA GTX260 EVGA SSC (X2 in SLI) both 652/1403
PS:Corsair 650TX
OS: Windows 7 64-bit Ultimate
--Cooling--
5x120mm 1x200mm
Zalman 9700LED
Displays: Samsung LN32B650/Samsung 2243BWX/samsung P2350
Kinda hard to do, when you re write a new program, there will always be faults. Its better, marketing wise. To release the software and have hundreds of thousands of people find the problems and down sides in it. Than it is to spend another 2 years, money and with 200+ people trying to do the same thing. Business wise, its better to let the public, that you sell the product to, find and determine downfalls and faults in software and release patches to fix them.
You will never, ever, ever see a piece of software that releases with 100% compatibility and 100% stability with no faults or down sides, ever in the history of technology. There will always be problems, there will always be downsides, there will always be upgrades.
RIGGY
case:Antec 1200
PS:Corsair 650TX
--Cooling--
5x120mm 1x200mm
Zalman 9700LED
[-AMD Opteron 165 @ 3.0Ghz-]
[-DFI LAN Party UT uNF4 Ultra-D-]
[-AData 4GB (4x1GB) DDR484-]
[-eVGA Geforce 8800GTS 640MB 320-Bit-]
[-Creative Sound Blaster X-Fi XtremeMusic-]
[-Seagate 160GB & 250GB 16MB Cache SATA300-]
[-OCZ GameXStream OCZ700GXSSLI-]
[-DELL 2005FPW LCD Monitor via DVI-D- & Westinghouse 22w3 LCD Monitor via DVI-D]
[-Windows Vista Ultimate x64-]
Vista itself is pretty damn stable, ok my laptop wouldn't hibernate under Vista for a while, but that was a manufacturer problem.
The only grunt I have against Vista is the "cached" application which helps to faster load time. I don't need or want that, I'd rather have more free ram than have all my apps "cached". Ok, and that Vista gaming performance is still a little slower, but should be fixed with more driver updates later on.
A wiseman once said, "If Bible proves the existence of God, then comic books prove the existence of Superheros."
I think so too. I have not run into one major problem, or even a small one yet. I've had one blue screen due to overclocking so its not a fault of Vista. With XP, one has so much troubles (usually) that you don't even count them "its a everyday thing".
But with Vista I have been very pleased since the first time I installed it. Its great and the performance just keeps improving (MS launched two patches today which improved performance according to the description).
+1 on the Vista doesn't suck bandwagon. Stable, good, I'm satisfied.
Ryan
"Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Abit IP35 Pro
Intel Core 2 Quad 6600 @ 3200 w/ Tuniq Tower
2x2gb A-Data DDR2 800
AMD/ATi HD 4870
no problems for vista for me... My gfx crashes under XP and doesn't under Vista Really weird don't know why but yay... lol
"Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
//James
People like NapalmV5 probably just read what people post online then spread more rumors and crap about it without having ever used it.
I admit, first week I used it, I didn't like the changes, but it's been extremely stable for me. In fact, the one time I BSOD'd, it was because I said I wanted to install the program despite having been given no less than 3 warnings saying that installing this will be a critical problem. So I BSOD'd on boot up but thanks to the built in recovery system, I recovered to the moment before I installed it and all was well again within 20 minutes. Had it been XP, I guarantee I would've had major issues.
No problems here. All my hardware seems to run as well as XP. I'm glad I made the switch to Ultimate 64bit.
i hope you don't work for MS and some other company doing sub contract work for MS.
your insinuation that it is better to release a "sub-par product" to hundreds of thousand prospective customers so they can deal with it not only insults me but physically outrages me to no end!
that is the most pathetic business plan that i ever heard about!
BIOSTAR TPOWER I45 UNOFFICIAL THREAD
BIOSTAR TPOWER BOLT MOD FOR HEATPIPE AND HEATSINK
BIOSTAR TPOWER I45 BIOS FLASHING PROCEDURE
ABIT IP35 PRO HEATPIPE MOD
ABIT IP35 PRO BIOS FLASHING PROCEDURE
IP35 Pro: 9650@4000Mhz, par overclocker; Freezone Elite; 4Gb GSkill DDR-800@DDR-1068 (2 x 2gb); XFX 8800 GTS; Areca 8X PCIe in Raid 0 working at 4x speed; 4-250 Gb (single platter) 7200.10 drives; Giga 3DAurora case with side window.
Athlon 64 3200+ | ASUS M2A-VM 0202 | Corsair XMS2 TWIN2X2048-6400 | 3ware 9650SE 4LPML | Seasonic SS-380HB | Antec Solo
Core 2 Quad Q6600 @ 3.0GHz | ASUS P5WDG2-WS Pro 1001 | Gigabyte 4850HD Silent | G.Skill F2-6400PHU2-2GBHZ | Samsung MCCOE64G5MPP-0VA SLC SSD | Seasonic M12 650 | Antec P180
Core i7-2600K @ 4.3 GHz @ 1.30V | ASUS P8P67 Pro | Sparkle GTX 560 Ti | G.Skill Ripjaw X F3-12800CL8 4x4GB @ 933MHz 9-10-9-24 2T | Crucial C300 128GB | Seasonic X750 Gold | Antec P183
