what is the difference between the dfi lanparty ut sli-dr, lanparty ut sli-dr expert, and lanparty ut sli-dr venus?. is it just the features or are they all the same with just more added stuffs.
the sli-dr has the older DFI layout with the memory above the cpu socket and the Venus has better capacitors
i guess you will find venus only on dfi site ( as picture )
expert for BH-5 overclocking, venus for 4x1GB overclocking, SLI-DR for TCCD/TCC5/UCCC
(iirc :$)
Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
32 GB Patriot Viper Steel 3733 CL14 (1.51v)
RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
Tons of NVMe & SATA SSDs
LG 27GL850 + Asus MG279Q
Meshify C white
This might help some.. http://www.xtremesystems.org/forums/...ad.php?t=94391
i got the dfi lanparty ut sli-dr and dfi lanparty ut sli-dr expert. when i went to the website my expert looked exactly like the venus which i saw on the website so i thought i had a venus. but when i booted it up it said it was an expert so i got an expert, now i know pictures can lie sometimes :S.
The only difference between Expert and venus are the cap's. if you look closely I bet you'll see the difference.
i have both boards so i know the diff
RIG 1: Asus Rampage Extreme X48
RIG 2: Foxconn BloodRage X58
E8600 Q820A349 @ 4.75Ghz: http://valid.canardpc.com/show_oc.php?id=596270
does expert like tccd? 8-)
If I recall the expert wasn't really good w/tccd but there was a modded bios that helped.
Gigabutt X58 OC F3 Bios
Xeon 5680 200x21@1.34V.Vtt 1.295V.
3x4 gigs Samsung 2Ghz 10,11,10,31@1.5V.
3xSapphire 5870
PCPC 950watt
what are the capacitors?.
