Hello
I want to know if my G.Skill GBHZ have Micron Chips!
The SN is: 0605090003178
Thx for help
Hello
Thx for help
i presume the ddr2 HZ rated for ddr2-800 at 4-4-4? then yes, it's most likely D9GMH, possibly, but unlikely D9GKX
Got a fan over those memory sticks? No? Well get to it before you kill them
on the label is DDR-800 CL4-4-4-15 but in the SPD is DDR2-800 CL5-5-5-15 ???
SPD is often set looser than stock on enthusiast sticks for better compatibility, just manually set it to where it should bein the bios
what that cant be right 2gbhz are rated for 4-4-4-12Originally Posted by tbonekot
0605 have Micron D9Originally Posted by tbonekot
0604 have Elpida IC
http://www.xtremesystems.org/forums/...d.php?t=101762
