Great results!
Did u tested this FX under a mach or vapo before? What was ur result there?
Great results!
PC : Asrock Z68 Extreme3 Gen3 + Intel Core i5 i2500k + 2 x Asus HD6870 DirectCU + 2x2GB PC12800 G.Skill Eco 7-8-7-24 + Creative X-Fi Titanium PCIe + Scythe Mugen 3.
Digicam : Pentax *istDL2 + Pentax smc DA 18-55mm F3.5-5.6 AL + Cosina F3.5/100mm Makro.
Heimkino : Samsung LE-46B450 FullHD + Arion AF-4000HDCI + Onkyo TX-SR505E + Quadral Quintas 5.0 + Heco Victa 25A.
Thx!
I've only tested it under water; just enough to pass OCCT at 3GHz with stock volts (38°C while loading).
This chip was C3's one; he may be able to answer you. BTW I don't know if he tested it under single stage phase.
Best Regards,
Xavier
"I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
Wonderful work there Too bad I can't say I supplied that cpu
Just one question though - how come there's such a difference in core temps from the first pic to the second?
Thx
The Spi32M was done with MPS multi processor drivers to fight cold-bug because they give extra heat load.
The setup won't even boot with divers for RAM clock higher than HTT. After all, i've used A64info to change dividers under windows and didn't need MPS drivers anymore.
Best Regards,
Xavier
But why would you use MPS Multi when running 32M and not 1M? I would think 1m would be harder to run without the tweak.Originally Posted by before
Using upclock dividers shouldn't be a problem even with the cold-bug. Cold-bug only limits HTT, and not mem speed
Awesome FX-57 You have
I haven't thought that 0516 can go so high with so cold evaporator ...I have rather thought that is work for 0530APMW ..I was mistake
Regards
Peter
http://WWW.PIOTRES.COM
My productions (phase-change and containers) : Click here to see links...
Phase-change units, cascades, chillers and Ln2/DI containers builder - contact : piotres@piotres.com
Thank u too!Originally Posted by before
It seems, that this cpu really likes the cold! My friend wrote C3 a PM about the results under single stage... it is just the question, if his FX55 0516WPMW scales like this 57 with the cascade. He did a validation today, with a mach2 and 3800MHz, with about +5°C. I think this cpu has potential, with the two stage cascade he will recieve the next week.
http://valid.x86-secret.com/show_oc?id=94717
Originally Posted by funkflix
He need to do his best again...... 0516WMPW too
under single stage default vapo Ls
http://valid.x86-secret.com/show_oc.php?id=57664
Love that first pic, looks like you found a nice one Before
let me decode that bad boy
"1241482E50213"....Nice job buddy!!
my jaw droped!
Go for 4.5
Nice one man ! =D. And to know that everyone was trying for 4Ghz only a few months ago with the same hardware =D
@s7e9h3n: In fact, I've found how to change the upclock dividers thx to A64Info freeware after running 32M. Thus the use of MPS was not needed anymore for running 1M.
@piotres: Thx buddy This FX-57 is really a great clocker. BTW It doesn't seem to have a unique memory controler, but can I be sad? Guess not!
@funkflix & Rol-Co: wOOt! That's a good FX-55 0516WPMW; I've owned one with core serial #484 but it didn't clock higher than 3705MHz suicide @-61°C core (it would do a little better with a tweaked OS, but just for few MHz). This FX-55 was also out of breath downwards -50°C core.
@G_H_Z: Thank you! That's lucky, I didn't expect to clock that high
@OPB: Thx bro! It seems me that you've decoded it right... I haven't really think about making it unreadable, but about highlighting both core & batch #
@bri1 & farsky: Thank you guys
Best Regards,
Xavier
4.2GHZ on AMD FX is sick!
I'm not even waiting for the valid link because I never validated an OC in this way on my own
good luck on getting benches >4 GHZ - I'm sure you will handle this
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
Great work before
VapoChill LS [AC] / QX9650 / X6800 / E8500 / Q6600 / CF-3870x2 / 8800 GTS G92 512 / XFX 7950GX2 (H20) / GeIL PC2-8500 C5 / PC2-6400 C4 / SilverStone OP1000 / ST75ZF
Abit IP35-Pro | 3DM06 - 18,264 | PCM05 - 23,577 | PCMVA 13,063
DFI 680i LT | 3DM06 - 24,602
Abit X38 QuadGT | 3DM03 - 120,337 | 3DM06 - 28,176
@SoF: Thx mate! Actually I'm waiting for R1150 for benches over 4GHz
@ncsa: Nice to see you here buddy! Thanks for your support! (sweet avatar you've got here...)
Best Regards,
Xavier
congratz Before with your WR, really an awesome chip you got there. I cant wait for the 3D benshes
DFI Lanparty nF4 SLI-D || AMD Athlon64 4000+ SD || 7900 GT|| GEIL 2*512mb BH-5 @250 Mhz 2-2-2-5 ||2*256 Old BH-5 285Mhz 2-2-2-5 || Tagan 530W
Super Pi: 25s:Pic
damn! 4.2ghz fx.. congratz!
LOL @ SPi, my 3.1ghz yonah @ 19.xxs
damn u intel.. lol
Good job m8
OCM rocks
Nice job man, hope I can reach the same limits with a 0530.
Concratz on the WR
Very nice job my friends !!!!
great result, keep up the good work !!!
Dell XPS M1730 - X9000 @ 3400mhz-4096MB 667MHz DDR2 - M8800GTX SLI- 17"WUXGA+
EVGA E762 4Way SLI Classified - 980X @ 6Ghz Ln² 6GB Dominator - MSI 5870 Lightning
WWW.MADSHRIMPS.BE - Being Mad Doesn't Hertz You
Thank you guys
@boblemaginifique: Yeh buddy, it's quite interesting to note, as you know, my FX-55 0516WPMW wasn't as a great cloker as this FX-57 0516WPMW, but was a far better memory controler...
Best Regards,
Xavier
Here's my last bench because I wasn't able to find better refrigerants... I've decided to sell the chip as I need money for Conroe
Best Regards,
Xavier
makes me a bit upset as I would have loved to see 4 GHZ 3DM01 with this chip
But if you can get this out of FX I'm sure you will rock on Conroe OC
