my prediction is somewhere around 45-50k or 70k ppd, it will depend if it crunnch like my i5 750 or like a phenom II thuban.
Based on the claim of one tiny WU that got in tonight it is showing a claim rate of 52,666 WCG points per day BUT I don't think all the cores are maxxed.
Now the reverse is that there's a rule of thumb going back to Kentsfields of 1.1 point per day per mhz so 24x1900x1.1= 50,160 so you may be right on the mark..:D
k10stat doesn't work with this.
From what I can see thats only if you have unlocked multi's and I don't.
Last think I can think of is get the numbers off the PLL controller and hope there's something there to work with.
Unless someone knows someone on Asus BIOS team..:p:
Now if only AMD would ramp up clock speeds on Opterons, ya know? :) WCG is already not very friendly to AMD's x86 cores. They're great at many other things however, as shown by my collection of AMD processor boxes. heh I had a 9800, then a 940, then a 955, then dual Opteron 2427s, a 1055T, and a 1090T. My latest and only Intel system is an E8400 from when Intel still had a manufacturing shortage of 45nm parts at their launch and they were fetching a premium.
We agree.
I see a hell of a potential here.
Nice running, powerfull even at this low a speed and temps that say to me that there's an easy 1000+MHz to be gotten and on air cooling with good HS and fans.
One issue I see is the HS mounts.
Two screws only and thats bad BUT these Dynatrons seem to be doing the job and these will mod just like the H46G's did.
77mm base,easy to mod 80mm fans to fitand get ridof these molded fans.
Had Vantec Tornadoes on Harpertown's at up to 3758mhz on this same design fan and they controlled the temps..
Blew your ears out but they worked.:rofl:
Bought a new pair of Vantec Tornadoes just in case I got the OC'ing to work..
These are essentially two Thurbans under each IHS so think 4 Thurbans at 1900mhz
Um, WOOOOHOOOOOOOOO! When can I take delivery? :D
Nice new toy Dave! Best of luck with clocking it. Oh and I drooled on my PC when I saw that Task manager! :D
What's the OC headroom of this CPU on a single socket MB? Can it get closer to @4GHz? In case, somebody should focus on making a OCable double socket MB/BIOS for this. Then it would get really interesting.
Are those the "kind loud like an airplane" Dynatron's?
Sorry,I can't hear you over the fans that sound like a 747 is spooling up the engines for takeoff..:rofl:
In bios there is also a "whisper" modefor the fans but I watched temps climb to 54C on that setting.
Key is to replace them with the Vantec Tornadoes bought and put on a fan controller and find that "right" evel between fan speed and noise..
Ok,bed calls.. Night guys..
Ok so no big overclocks due to locked multi. Is there a way to adjust the IMC / L3 speeds? I guess its ok though because the strength of this machine should not be clockspeed but the number of cores and the power / performance ratio.
However, knowing that stephen did well over 3Ghz on stock volts is kind of frustrating.
What's the PLL?
And here we thought you were going to bed, are those fans keeping you up? You can always send my dual Magny-Cours to me if you want :D
Those fans are powerful enough to rip a hole in space-time. I wonder if they actually suck in noise when running backwards. Hey, it would work in Star Trek.
