Yep that is one nice Xeon. Failing that, I'd definitely get a Q9650. Mine does 4GHz on X48 (One REX, also on my DFI) boards easily.
Does it have an unlocked multiplier?the X3380 i mean
The x3380 has a locked multiplier but it has the highest default quad-core multiplier (9.5) for socket 775.
this is my X3380 on water no AC just ambient love this chip
http://img180.imageshack.us/img180/9071/p1050680.jpg
http://img576.imageshack.us/img576/3...cr2pl7linx.jpg
this on W7x64
http://img828.imageshack.us/img828/6627/50061.jpg
this on XP32 on my UD3P and other WC that needed AC i had a thin rad
http://img413.imageshack.us/img413/4206/sp11m12.jpg
cheers :toast:
Sergio
that is a killer set up. top notch work!
that Xeon X3380 would be right up your ally, forget the QX9650/QX9770
Ok guys, you convinced me, I just bought the X3380 from Systemviper. Can't wait to receive it and try it out!
Thanks all for your advice :) If you have any "overclocking tips" on a DFI X48-T3RS please let me know :)
I'm trying to find a guide for my DFI's bios, here on xtremesystems but can't seem to find it :( Anyone knows of a good guide
for the so complicated DFI x48 T3RS bios?
p.s. xeons don't have any compatibility issues with other hardware or programs right??
Cool! The baby is on its way :) Now gimme some times for ocing it properly :P :P
X3380 is cool stuff indeed and I'm looking forward to see your results.
Thanks oldcomer!! Now I need 2 things, maybe you can help me
1. DFI bios guide
2. I'm thinking of going for SLI hack no my x48 T3rs, are the latest drivers of nvidia available with the mod? Is it possible to mod all releases that follow?
The baby has just arrived!! I received systemviper's X3380 :) I still haven't tried it though, it sucks i need to wait a few days for the chipset heatsink to get here!!! :D EXCITEEEED
Just FYI, I'm running at QX9770 with a Corsair H50 and a P5Q Deluxe at 4.3GHz 1.45V without any problems. I used to run a QX9650 at the same speeds as well but it required more voltage.
I have my x3380 @4.20ghz 1.4v quad pumped dual channel with h100i stable, temp during prime95 with case shut and ambient temp 25c... cpu max 80c
Sent from my GT-I9100
nice to see the X3380 is still going strong.
Yep :) its a nice little beast. About to get a couple of new friends to keep him company..2 gigabyte gtx660ti oc cards :)
I think hard to find...I got mine from system viper a long time ago here in this forum
