Originally Posted by
ugotd8
Thanks ! That looks great. Took me a few minutes to realize the PMP-400 is a rebadged DDC. :-)
Two questions if I may, one, does the coupler have to end up where the nozzles are perpendicular to the outlet on the pump top? I'd really like them to be parallel and on the same side. Two, do you know of another shop that carries this stuff ? (Sure wish sidewinder did).
I have the pump and waterblock apart. Didn't see anything terrible on disassembly. There is what looks like light brown gunk on the top side of the impeller, very hard to get to. Also, the waterblock copper fins appear to be warped or bent at the return. Which brings up another question, did I pair the wrong waterblock with this pump ? The Apogee XT is said to be a very restrictive block (sure has one tiny opening for the inlet). This was (is) my fisrt loop and I have to admit, besides the noise it didn't really perform up to my expectations. I would obviously like to do this as inexpensive as possible, but I'm going for super-quiet with great performance if that's possible. :-)
