Just wanted to see what results everyone was getting. I was thinking of using this chip in some clients pcs. Wanted to be sure that it could at least get to 3.5ghz stable. I have it in a p35 board and don't know if I got a bad chip or what??
Right now I can't get this thing above 3.5ghz, where is the guy who go 4.3ghz on air can you shead some light on how you did that??
i got the one i have atm to 4.3ghz on air as well, but with lots of volts.. i could get 4ghz with around 1.475ish volts tho
look this http://www.xtremesystems.org/forums/...d.php?t=204640
My E5200 MAX FSB 425 ON AIR 4.5G+ RUN MARK
VID 1.125V
LN2 5.2G+ MARK
Oh man i think that i have to buy same chip at christmas. ;)
guys: heres my current settings... any suggestions???
1) do u reccamend any tweaks/setting changes without bumping up my vcore? i want to get 3.7ghz or3.8ghz stable without vcore changeQuote:
3.60ghz @ 1.38125v BIOS ***currently testing with prime95*** oct 18/08 9:30am est.
using the asus p5q pro stock bios 1106, with G.SKILL F2-8000CL5D-4GBPQ PC2-8000 4GB ram
FSB frequency ==============> 300 x 12
pci frequency 100
FSB strap to northbridge auto
DR ram freq < 800 mhz >
DR ram timing control manual settings
DRRAM Timing Control [Manual]
CAS# Latency [5]
DRAM RAS# to CAS# Delay [5]
DRAM RAS# Precharge [5]
DRAM RAS# Activate to Precha [15]
RAS# to RAS# Delay [5] <--Auto is on 3, too tight
Row Refresh Cycle Time [45]
Read to Precharge time = _____________??? value is 1 to 15
DRRAM Static Read Control [Disabled]
DRRAM Read Training [Disabled]
MEM Overclocking Charger [Auto]
AI Clock Twister [Lightest]
AI Transaction Booster [Manual]
Common Performance Level: [9] <---7~8 maybe possible???
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
DR ram static read control disabled
DR ram read training disabled
MEM overclocking charger auto
AI clock twister lighter
AI transaction booster manual performance level = 9 settings
cpu voltage 1.375v >>> 1.38125v
cpu gtl return .61x
cpu pll voltage 1.54
FSB termination 1.34
DR ram voltage 2.14* want to go lower tho ram is rated 2.1v
NB voltage 1.36 >>>>1.40v
SB voltage 1.20
pcie sata voltage auto
load line calibration
cpu spread sprectrum
pci spread strectrum all disabled
cpu clock skew auto
NB clock skew auto
cpu margin enhancement optimize
in Advance CPU settings:
CPU ratio is 12x
C1E support disable
max CPUID value limit disable
CPU TM function disable
Execute Disable Bit disable
Intel speedsteptech disable
intel C-stateTech disable
2) usally when i run prime95 blendtest, i'll get BSOD and puter auto reboots into bios, is that RAM problem or cpu too stressed out
3) my ram is the G.SKILL F2-8000CL5D-4GBPQ PC2-8000 model, but im running mine at only 800mhz :( , no ocing , do u have good settings for ur 500mhz?
i will try that memtest vista GUI prog, i've used memtest86+ in the bios to test my ram bfore tho
cheers if u can help me thanx
Here is a system I just built....
http://img520.imageshack.us/img520/1...3652gr4.th.jpghttp://img520.imageshack.us/images/thpix.gif
INTELBURN stable max temp is 66c on air.
3.5ghz Fast little chip.
I have is set at 333fsb x 10.5. This lil chip is quick!
Just have to let you guys know, for the money this lil chip is badass!!! My last 2 builds for people I've used this chip overclocked to 3.5ghz 333 x 10.5 and it is burn stable for 20 passes max temp is 65c. This lil chip is fast with it overclocked and a 9800gt overclocked I can play crysis all high at 1920x1200. Not Bad. No one else has this chip an is overclocking it??:confused:
These CPU's are crap unless you buy them from scratch or you somehow get ES chip from someone. Or you're just insanely lucky to get good retail chip. Otherwise they have tendency to hit FSB way too fast and only thing that saves them in the end is high multi. I ended up installing back my trusty E4300 which at least clocks FSB properly.
Overall i was rather dissapointed with it...
It would be nice if posters esp. those with good chips can add in the more chip details eg. batch, VID etc.... I had a Costa Rica retail chip which walled around 310FSB so yeah, these chips aren't that appealing to me despite the high multiplier.
http://s9b.directupload.net/images/u...p/6uiwy6eu.jpg
http://s9.directupload.net/images/us...p/gm2sh3pf.jpg
got another one with vid 1.1875, needs 0.1v more for 3,7ghz but doesnt get that warm and takes ~5w less power. i hope i can test those 2 babes with a good p45 mobo instead of ma 945GC Asrock crap :shakes:
So far OCCT-stable at 3.9Ghz at 1.38VCore.
Needs 1.24 for 3.6Ghz.
Boots easily into 320x12.5=4Ghz at 1.37VCore (load) but not stable..yet. :)
Edit: OCCT-stable with 1.40Vcore (load)
http://s10b.directupload.net/images/...p/w6sid6ks.jpg
i guess that chip isn´t that bad, i always thought. with some good watercooling there should be nice results :up:
under the Christmas Tree i found one of those E5200 CPU's. nice toy four me :D
I have not much time for testing, but i think my results arn't that bad. My Target was too get 4Ghz out of this really cheap CPU, no madder if Prime stable or only for a screen.
My Setup:
E5200
Crucial 533er DDR 2 Ram with D9GMH's
good old Asus P5b DLX Wifi AP
self build 50€ Wakü
I bootet my mashine and it freezed when i took it to 3,6ghz.....but then i realized the vcore was at only 1,05V :p:
i put the Voltage up to 1,5V and continued.....4 ghz run fine and i raised the clocks more and more.....i couldn't belive my eyes when it was at 4,5 Ghz :P
Than i took a Prime screen at 4ghz, what was my original goal. My Room Temp was 22 Degree and a bit less Voltage iss possible, but not much.
http://http://www-e.uni-magdeburg.de...ghz@1,392V.JPG
Then i tried to get all out of the CPU and made a 1M run at higher voltage, with dirty windows and not optimized that much, but i think the clocks are nice for a cheep cpu like this =)
http://www-e.uni-magdeburg.de/jrehfe...ng/12,907s.JPG
Last i made a screen shot of max Mhz
http://www-e.uni-magdeburg.de/jrehfe...z%20screen.JPG
if my studies leave me enough time this weekend, i will do an outdoor session, and hope to get 5ghz out of this little bastard :slapass:
Best Christmas Present to my Ocer Heart ever, thanks to my Brother :up:
little more's to 5ghz......:D
i have one chip to, stable at 4,1GHz @1,48v.....the chip look so cool
using Gelid Silent the temp in full load when i test orthos at 72c.....
i think need more powerfull coolling......hehehehhe......:D
do you guys mind posting the batch/fpo and max oc on your e5200?
Q828B334 (Malaysia)
http://thumbnails15.imagebam.com/314...7931400363.gif
http://thumbnails9.imagebam.com/3141/ed251d31401972.gif
4ghz 1.24V :eek:
I think i got lucky :D
The temps with this chip are pretty high :shrug: and fsb wall is around 380, but with 12,5x multiplier is not something to worry about.
I'm planning on building a pc and OCing one of these on high end air (scythe mugen 2). 4.0 ghz+ realistic on a GA-EP45-UD3R? I have ddr2 1000 I can swap out if I need a lower multi, but it appears my ddr2 800 kit will be overkill.
e5200 on UD3R @3.5/3.6 @1.25v with stock cooler right now. Once I get it in the water cooling rig, I'll go for 4ghz then update this.
Here's my E5200 wif ASUS P5N7A-VM, however it cannot pass SP2004 Orthos.
Batch Code: Q834B135
http://bbs.ocqq.com/attachments/foru...229801024c.jpg
And the CPU PCB's the same as the E8x00 series, which helps pushin da OC limit more than normal ver. of E5200.
http://www.hkepc.com/forum/attachmen...L7UcqhetZv.jpg
(Pic copied from PCOnlne.com.cn)
