Hello,
My problem is:
I have a decent Q6600 with a 1.2250VID.
He runs 3.7Ghz around 1.384V stable the previous owner said and i can confirm this.
Either, my mobo is strange acting (or bios is some strange thing...).
When i boot 400 x 9 and all voltages on minimum (except vcore) and i use the 333 strap with 1:1 divider, it runs stable!
When i set like 415 it boots but at windows it gives me BSOD. This keeps happening even if i up the voltages off NB/PLL/VTT etc etc...
BUT, when i use the 266 strap with 4:5 divider (lowest on this strap) it boots fine till 435 FSB... The northbridge needs some more voltage becuase off the tighter strap but it's so stable as what...
None off you guys with P5Q-E got this ? I tried every bios and all off them got it...
I just want to use the 333 strap with 1:1 divider and clock to 475 x 9 for some benching... If i got to use the 266 strap i'm on a ram clock off 593Mhz that my current ram can't handle... Tuesday i get PC9600 ram and then i can get this but i want to get this even without that ram. Why wont the 333 strap with 1:1 divider work above 400 FSB ... ??? Also, 400 strap, never ever posted since i get the board. You got this to ?
Sorry for the grammatical mistakes, but you understand me anyway ;) .
Any help is welcome !
EDIT:
To make it some understandable...
FSB : 400
FSB Strap : 333
RAM : 1:1
CPU Voltage : 1.40000 v
CPU GTL : AUTO
CPU PLL : 1.52 v
FSB/VTT : 1.22 v
DRAM : 2.10 v
NB : 1.12 v
NB GTL : AUTO
SB : 1.10 v
PCIe : 1.50 v
This is 1000% stable with IntelBurnTest and Prime95...
But when i use the same settings but then 401 FSB, it boots but is far from stable.
Even this:
FSB : 401
FSB Strap : 333
RAM : 1:1
CPU Voltage : 1.425000 v
CPU GTL : AUTO
CPU PLL : 1.54 v
FSB/VTT : 1.30 v
DRAM : 2.10 v
NB : 1.20 v
NB GTL : AUTO
SB : 1.20 v
PCIe : 1.60 v
But the good news is, if i use this :
FSB : 435
FSB Strap : 266
RAM : 4:5
CPU Voltage : 1.45000 v
CPU GTL : AUTO
CPU PLL : 1.60 v
FSB/VTT : 1.34 v
DRAM : 2.10 v
NB : 1.38 v
NB GTL : AUTO
SB : 1.20 v
PCIe : 1.60 v
It's perfectly stable... And the 400 strap never ever posted and gives me also 15 min work to get the board working again...
