SP1 for Vista is TLB override KILLER!
Sad story first: I've installed SP1 on my home machine, and then after seeing unbelievable outcome tried on test system :(
System is: Phenom 9900+M3A32-MVP+4GB DDR2 800 (CL4 unganged)
TLB override in BIOS Enabled!
Prior to SP1 install:
http://img91.imageshack.us/img91/285...bledpz6.th.jpg
After SP1 install (no changes in the BIOS options):
http://img91.imageshack.us/img91/572...bledya6.th.jpg
:shrug:
After SP1 install AOD didn't have yellow ring around "turbo" button, and I knew that something is wrong... I've pushed button to yellow status but no changes... TLB patch is ON and it CAN'T be disabled!!!
This is a nightmare for all of us B2 owners!
Now I’ll need to re-install Vista on home machine and wait for M$ to publish very first patch for SP1!!!:down:
Update!!!
I've tried this: http://www.xtremesystems.org/forums/...d.php?t=180338
and it works! so AOD doesn't work, BIOS override doesn't work! But this fine work of our forum member works!!
