PA 120.3 and MCR320 in parallel
If I put a PA 120.3 and a MCR320 in parallel, would the water flow through each one about equally? I am thinking of adding another rad to my loop and I have a MCR320 I'm not using. I know I could do 2 loops, but then I'd have to have another pump and more holes in the case (externally mounted rear radiators). So I was thinking of just adding the MCR320 to my existing loop. But then I was thinking, should it go in in series or parallel. After some searching here, it seems like parallel would be better.
And yes I'm after that elusive .1C :)
Any advise is greatly appreciated.
]Monty[
