OCZ TCC5 Overclocking Results?
I've been tuning my OCZ Platinum Rev 2 v1.1 TCC5 and was wondering if anyone had timings/results to share?
I've been testing for 5 passes of Memtest #5 till I find the max so I can test at 95% of max for 50 passes. So far I'm at 305MHz, 2.5-4-6-3-8-15-3-2-1-2-3072-1-E-A-0-7-2-8-5-A-D-16-7-D. Memory bandwidth is around 3470MB/s at 305x9. LDT=1.4, Chipset=1.6, DRAM Voltage = 2.9+0.3
I've written down every tweak and its result but it's at home. For some reason I get more errors with trfc=16, twtr=2, or tref=4708. R/W Queue Bypass at 8x or Bypass Max at 4x doesn't seem to make a difference and 2.93V gives me the least amount of errors. I'm using BIOS 414-3, and have a 90mm fan sucking air from RAM, 80mm fan blowing air to RAM & mosfet.
PCB B6U808
SAMSUNG K4H560838F-TCC5
513
OCZ Plat REV 2 V1.1(TCC5)
Hi all....
well being in India is not that good for overclockers.... anyways heres wat I could get out of my 1GB set of OCZ Plat Rev 2 V1.1 (TCC5).... ya I am late for this. But Didn't get time, sorry.
250, you may say nothing gr8 here! Actually goes up to 255 with 2-3-3-5!
http://img450.imageshack.us/img450/2...zpi80wi.th.jpg
290 Finally, this is what Windows Stable I have got with my X2.
http://img127.imageshack.us/img127/5...90pi1im.th.jpg
So... I can do 290 but not the 300. Kinda left out feeling, but otherwise its Rocking as DDR400 able to do DDR580.
Wat more can One ask for?
