CrazyNutz, the observations made by
trayton brougt up my doubts regarding voltagetables again.
you said kgb will flash all tables to the same value and boost voltage simply will be selected by stepping up the voltage two steps in the standard table:
The two voltage tables for GK104 bios are always the same values. The boost logic automatically boost the voltage up 2 levels.
You have notice i'm sure that your stock volts 1.150v will go to 1.175 on boost.
1150000
1162500
1175000
1187500 < my tool sets the voltage tables to this
1200000
1212500 < The boost logic will bring it here, (if the GPU is cool, and not drawing too much power)
first question here: is this the complete table or are there any lower or higher steps available?
there are six voltage values displayed when running kgb. could you elaborate what this six voltage values relate too?
from a logical point of view it would make sense, that some levels relate to standard voltages and some other relate to boost voltage.
need to think a bit about this and see how i can verify this with my lightning. but as you know, lightning cards have their own voltage control
and simply add some offset voltage on top of the voltage delivered by the standard nvidia voltage controller. at least thats how i understand this.
so the most interesting question to me is: what is the meaning of this six voltages displayed and modified by kbg? may be we come to the conclusion
it would be best to change all this voltages independently. than we can check with the multimeter whats really going on ...
anyway, great tool! thanks for your work!
