Not sure yet. Eventually I will get around to a 3d shootout with all 3 boards but likely not with dumo's. I'd like to compare on mature bios's across all boards.
Seeing as no one has seen the MSI yet......not sure how you could draw that conclusion?
The particular board your currently using is an excellent 3d03 board for instance.
It beat the ASUS 890GX with 2x 4850's and got top 10 at min on bot with a cpu on phase and cards on air.
http://hwbot.org/community/submissio...0_102317_marks
The ASUS 890GX however traded blows and won in 3d05......
There is no such thing as a perfect board. Only a perfect board for a specific app "target" if you will.
