5870 Bottleneck Investigation (CPU and/or Memory Bandwidth)
The 5870 is fast, that's for sure, but looking like and enhanced and doubled 4890 it should be much faster, and definitely shouldn't be beat by 4890CF across the board. The card has power, but obviously isn't able to use very well. The two main culprits are immature drivers and a possible bandwidth bottleneck. While we have to wait and see for drivers, anyone with a 5870 in hand can easily test if the memory system is at fault.
This is a call for anyone who has a 5870 right now, and if no one steps up to the plate I will when mine comes in. A good methodology would be dropping the core and memory frequencies in half while observing how the performance changes across various programs (especially those that the 5870 doesn't scale well in, like hawx) as core and memory are individually adjusted. Come on guys, lets get to it!
58xx CPU bottleneck investigation
I'm benching my unlocked 720BE against a guy with that has a 5870 and i7 over at OCN... results are less than exciting (for me at least)
I just ran Crysis Warhead bench 0.33 (avalanche flythrough)
1920 0xAA
i7 @ 4.2Ghz Min: 29.55 Max: 46.81 Avg: 37.04
Phenom II x4 @ 3.6Ghz Min: 25.12 Max: 36.73 Avg: 30.99
1920 8xAA
i7 @ 4.2Ghz Min: 21.29 Max: 37.74 Avg: 28.65
Phenom II x4 @ 3.6Ghz Min: 18.24 Max: 29.33 Avg: 23.83
note: Unlock from X3 to X4 gave me a slight avg fps increase, and almost 2fps increase in min fps.
It appears since the min FPS numbers are all very close, they are revealing spots where the bench is GPU limited, and the Max FPS numbers are quite different, showing spots where the bench is CPU limited
Anyone who owns a 5870 and wants to add benches into the mix is welcome... I'll run the same bench if possible on my system and we can see what can be worked out about this. OBVIOUSLY a 3.6Ghz Phenom II is no match for a 4.2Ghz i7, but I would have though that the results would have been much more GPU limited in this bench. :confused:
